Hi! I’ve been trying to set up ClusterODM according to the documentation and some of the posts on this forum. Though I’ve met success in some steps, there are some pieces that aren’t connecting with each other.
Here are the steps I’ve followed so far -
Secondary Machine: (192.168.1.2)
docker run -p 3001:3000 opendronemap/nodeodm --max_concurrency 8 --max_images 1500
Primary Machine: (192.168.1.10)
# Start WebODM with 0 Nodes
$ ./webodm.sh down && ./webodm.sh update && ./webodm.sh restart --default-nodes 0
#Start a Node With no of processors and max images as arguments
$ docker run -p 3001:3000 opendronemap/nodeodm --max_concurrency 18 --max_images 1000000
cd ClusterODM
npm install
docker run --rm -ti -p 3000:3000 -p 8080:8080 -p 10000:10000 opendronemap/clusterodm
telnet localhost 8080
#> NODE ADD 192.168.1.2 3001
OK
#> NODE LIST
1) 0.0.0.0:3001 [offline] [?/?] <engine: ?> <API: ?>
2) 192.168.1.2:3001 [online] [0/1] <engine: odm 2.8.0> <API: 2.2.0>
#> NODE LIST
#> NODE DEL 1
OK
#> NODE ADD 127.0.0.1:3001
INVALID
#> NODE ADD 127.0.0.1 3001
OK
#> NODE LIST
1) 192.168.1.2:3001 [online] [0/1] <engine: odm 2.8.0> <API: 2.2.0>
2) 127.0.0.1:3001 [offline] [?/?] <engine: ?> <API: ?>
#> NODE DEL 2
OK
#> NODE ADD 0.0.0.0 3001
OK
#> NODE LIST
2) 0.0.0.0:3001 [offline] [?/?] <engine: ?> <API: ?>
My questions -
- I can’t seem to connect the node I have on the same machine to ClusterODM. What am I doing wrong here?
- I am not able to connect the ClusterODM instance to my webODM app through the GUI. How can I achieve this?
I suspect that both these issues have to do with the docker IPs, but it doesn’t make sense to me intuitively as
