I’ve already checked the forum and other sources for similar cases. But I didn’t find anything.
I have tested 43 images without GCP file. Works perfectly.
Then I took the same 43 images with a GCP file and the calculation was aborted. I got the following error message: fed51893-05a1-432d-80f4-a0818b23fed6 not found.
Format of the GCP file: x y z pixelx pixely imagename
I have also tested different variants of the GCP file:
EPSG:4326
EPSG:4326
However, I always get a similar error message.
I would be very grateful for help.
