Please help me, it doesn´t open
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Initializing console…
OpenSSH check passed
SET DOCKER_TLS_VERIFY=1
SET DOCKER_HOST=tcp://192.168.99.103:2376
SET DOCKER_CERT_PATH=C:\docker-webodm\machines\webodm
SET DOCKER_MACHINE_NAME=webodm
SET COMPOSE_CONVERT_WINDOWS_PATHS=true
REM Run this command to configure your shell:
REM @FOR /f “tokens=*” %i IN (‘docker-machine --storage-path C:\docker-webodm env webodm’) DO @%i
Setup env variable: DOCKER_TLS_VERIFY=1
Setup env variable: DOCKER_HOST=tcp://192.168.99.103:2376
Setup env variable: DOCKER_CERT_PATH=C:\docker-webodm\machines\webodm
Setup env variable: DOCKER_MACHINE_NAME=webodm
Setup env variable: COMPOSE_CONVERT_WINDOWS_PATHS=true
Setup env variable: COMPOSE_TLS_VERSION=TLSv1_2
Item has already been added. Key in dictionary: ‘DOCKER_TLS_VERIFY’ Key being added: ‘DOCKER_TLS_VERIFY’
Item has already been added. Key in dictionary: ‘DOCKER_HOST’ Key being added: ‘DOCKER_HOST’
Item has already been added. Key in dictionary: ‘DOCKER_CERT_PATH’ Key being added: ‘DOCKER_CERT_PATH’
Item has already been added. Key in dictionary: ‘DOCKER_MACHINE_NAME’ Key being added: ‘DOCKER_MACHINE_NAME’
Item has already been added. Key in dictionary: ‘COMPOSE_CONVERT_WINDOWS_PATHS’ Key being added: ‘COMPOSE_CONVERT_WINDOWS_PATHS’
unable to resolve docker endpoint: open C:\Users\luis_.docker\machine\machines\default\ca.pem: The system cannot find the path specified.
webodm - virtualbox Running tcp://192.168.99.103:2376 v19.03.12
