Can someone please help me fix this?
https://flic.kr/p/2jbDVXj
How do I fix all the missing textures?
There are ways to fill the gaps, but the best way to fill them is by flying a larger area than you need: these are occlusion areas: you simply don’t have enough of the pavement around the building. Set your flight area larger that you think you need.
It works fine w/ default settings. I did get it to work before w/ no gaps but I’m not sure what I did. Default settings makes the perimeters of the buildings all messed up.
Can you post your settings for the bad result?
How do I post it?
I just want to know what it takes to make the white triangles disappear.
texturing-keep-unseen-faces to Enabled fixed the problems
Fantastic. Thanks for sharing what worked!
