Can not start virtual machine
Could not start virtual machine. Check the console for error messages and attempt to fix the problems manually, then restart this application
I am trying to open Webodm manager and I keep getting a fault as above. When I look at Oracle VM VirtualBox it states Failed to open a session for the virtual machine webodm .
UUID {13b50043-3036-456e-8202-88e1e301d529} of the medium ‘C:\docker-webodm\machines\webodm\disk.vmdk’ does not match the value {46584fd1-dbfd-4274-b7ab-18592454e5ac} stored in the media registry ( ‘C:\Users\tonyd.VirtualBox\VirtualBox.xml’ ).
Result Code: E_FAIL (0x80004005)
Component: MediumWrap
Interface: IMedium {ad47ad09-787b-44ab-b343-a082a3f2dfb1}
Any help appreciated as new to this
I’m not sure of your level of experience, but initially I found VirtualBox to be somewhat cumbersome to wrap my brain around. Unless you are up for the project/challenge, I would recommend to uninstall everything and simply try again and don’t mess with many settings other than memory and processor. In theory it should install correctly and run great with mostly default values.
