Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Initializing console…
OpenSSH check passed
‘docker-machine’ is not recognized as an internal or external command,
operable program or batch file.
WebODM VM does not exist. We’re going to create it now… hang on tight! If this takes more than 10 minutes, please try restarting your computer.
create --virtualbox-no-vtx-check --driver virtualbox --virtualbox-disk-size “150000” --virtualbox-memory “9156” --virtualbox-cpu-count “4” webodm
Uh oh! Check the console. Check that you have enough memory available, disk space, that your firewall is off and that you have restarted your computer. Refer to the troubleshooting section of the installation manual for more information.
what could be the problem. I am not so techy about this.
