Calibrated Cameras for NDVI
I am looking to use this for processing NIR and RGB images to make an NDVI index. Does this software calibrate the images to make the images using sunshine/reflectance?
Not yet. It is an oft requested feature, but no one has yet had the time or funding to pursue it.
Could you do it in pre-processing and then feed ‘reflectance’ images through ODM? I’m using a Micasense RedEdge camera, and have created digital reflectance images (in jpg format - you just divide each band by 255). Would each image in the stitching retain its properties? Or does ODM modify the images in such a way that the reflectance data would then also be modified?
It will modify it some, through blending and matching, but should broadly keep the same values.
