I achieved success with build 47 in processing a 9400 image project, generating ortho, dsm, dtm and 3d model. Remarkably, it completed in 43 hours! My previous issues Problems with logging and clock - #8 by itenviro have mostly been resolved, either by the latest build or by my uninstalling blender meshlab and whatever programs I felt might conflict with webodm.
A few minor issues remain.
- The progress bar. Works for upload images and showing completion but during processing - no green showing, only the spinning gear.
- pgsql.log shows only a login authentication error at time of creation and no other data.
- 3d model. model is rendered with texturing at minimum point budget, but increasing points or splat crashes potree. Renders fine in meshlab.
pgsql.log
LOG: database system was shut down at 2021-12-03 12:23:18 EST
LOG: MultiXact member wraparound protections are now enabled
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
FATAL: password authentication failed for user “postgres”
DETAIL: Password does not match for user “postgres”.
Connection matched pg_hba.conf line 86: “host all all ::1/128 password”
note - not sure where db shutdown time above came from as project was started 12 05 and I had deleted webodm and other pg programmes and cleaned registry etc. - apparently not successfully.
app.log
“Trying to connect to postgres localhost:29543…”
“D:\WebODM\resources\app\apps\pgsql/bin/pg_ctl: server starting\r\n”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: psql: FATAL: password authentication failed for user "postgres"\r\n”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 2”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: exited with code 0”
“Setting postgres password…”
“D:\WebODM\resources\app\apps\pgsql/bin/psql: ALTER ROLE\r\n”
“Postgres password is set”
there is also a strange line in the app log:
“python: D:\WebODM\resources\app\apps\grass78\Python39\lib\site-packages\rasterio\io.py:134: NotGeoreferencedWarning: Dataset has no geotransform, gcps, or rpcs. The identity matrix be returned.\r\n return writer(mempath, ‘w+’, driver=driver, width=width,\r\n”
I am not sure what this line refers to as a gcp map is produced and there are numerous mentions of the gcp file in the app.log
