Bounds are not valid
I deploy WebODM on Windows 11 and I have a problem with the import.
I would like to import files that I have already processed in the past with other tools, such as AgiSoft, in order to use the WebODM viewer.
I would like to embed .tiff files for the viewer with the map. I tried with jpeg + jcp but I always encounter the same error, “Bounds are not valid.”. This is my problem.
I would also like to integrate .las files for the 3D viewer, is this possible?
Thank you in advance for your answers.
This isn’t a supported workflow, unfortunately.
Are you able to re-process from the original source images?
