Hi there
Thx for a great tool. Regarding GCP´s. I find the GCP workflow somehow intricately in WebODM.
There must be a better workaround or? I work as a GIS professional and haven´t yet found any good method that avoids the manually click-in-map-and-save workflow. Or maybe I´m doing it the wrong way. Is it not possible to import the GCP´s into WODM, where it gets projected and placed correctly in the web map - and from there modiifying the correct location in the GCP interface(left side panel) ?
For example I have a file from field survey with the z value included that I want to import. And from there build on with WebODM.
