Process exited with code 1
No he podido tener resultados con el software WebODM
Estas son las imagenes
https://drive.google.com/open?id=1gpQKTS_u3Soezjf8bkesJr_7TyUlvH4F
English response below
Hola,
Estoy descargando las imágenes para ver si puedo procesarlas en mi ordenador, pero mientras tanto hay unas preguntas que pueden ayudar a entender tu problema:
1- Veo que son cerca de 200 imágenes. ¿Qué parametros has usado en la misión?
2- ¿Qué procesador/RAM tienes?
3- ¿Qué parámetros de procesado has utilizado en WebODM?
4- SerĂa de ayuda ver en quĂ© parte del proceso has tenido el error: ÂżPuedes copiar y pegar el mensaje de error para que podamos ayudar?
Por favor, intenta escribir en inglés las siguientes respuestas, de forma que la comunidad pueda ayudarte.
English text
I am downloading the images to see if I can process them in my computer, but there are some questions that could help in understanding your issue:
1- I see that you have approximately 200 images. What parameters did you use in the mission?
2- What processor/RAM do you have?
3- What processing parameters did you use in WebODM?
4- It would be helpful if we could see where did you get the error: could you copy and paste the error message so we can help?
Please, try and write your replies in English, so that the community can help better
I have processed a subset of 60 photos to see if the process worked, and I get no error messages.
It is likely that you ran out of memory at some point: have you installed WebODM via Docker? How much memory have you allocated to the image? You can see/change that (if you are using Windows) by right clicking the Docker icon on the tray → settings → Advanced.
I processed the images using the “Fast orthophoto” option, to get a quick overview of the results. Please, could you give some more information on what you want to achieve?
I agree with @northern_mapper, it definitely looks like a resource issue. I processed the full dataset and it’s fine: https://dashboard.aerosurvey.co.nz/public.cgi?S=404&T=70e8c6a9-5ffe-416a-ab73-0299b9b2e279
