I am a beginner and am learning to generate NDVI outputs. I came across this particular dataset on GitHub. Can someone tell me what are the bands in the images and in what order?
That’s my data
Typical RGB sensor, using the KolariVision Blue/NIR NDVI filter.
So, Red is basically pure IR, Green is mostly IR, and Blue is Blue/non-IR returns.
There is some bleed across channels.
If you poke around, you’ll see my CVI experiments where I’m trying to fine-tune band ratios for max contrast using that filter.
ENDVI works fairly well on that filter.
I was unable to get a 1:1 mapping of my spectra to in-field measurements taken at leaf-level with an NDVI Sensor (Precision Planting), but it was pretty much 100% correlated, so it still shows relative health perfectly fine.
Thanks a lot for the insight!
I’ll try to put up more/better information about the filter into my CVI repository soon(ish?). I’m also interested in improving that band index still, just don’t have super much time to dedicate to it.
