Hello. WebODM created a lovely orthophoto for me (yay!) but when I played around with some vegetation indices in QGIS I noticed they seemed a little strange. The orthophoto metadata for band 4 and 5 are just labeled “gray” not “rededge” and “NIR”. So, it is not possible to check which band is Rededge and which is NIR.
- Does WebODM output bands in the same order as the input images (MS Rededge camera, so input order is RGBNRe in this case)?
- Is it possible to update the orthophoto metadata to have the actual band name instead of “gray”?
GDALMetadata>.
Item name=“OVR_RESAMPLING_ALG”>NEAREST.
Item name=“COLORINTERP” sample=“0” role=“colorinterp”>Blue.
Item name=“COLORINTERP” sample=“1” role=“colorinterp”>Green.
Item name=“COLORINTERP” sample=“2” role=“colorinterp”>Red.
Item name=“COLORINTERP” sample=“3” role=“colorinterp”>Gray.
Item name=“COLORINTERP” sample=“4” role=“colorinterp”>Gray.
Item name=“COLORINTERP” sample=“5” role=“colorinterp”>Alpha.
