Hi all,
I recently gained access to an Azure VM with 2TB RAM and 4TB SWAP
I started processing 8054 images.
The processing stopped after 4 days and 19 hours.
I placed all of the jpg files in /home/declan/datasets/CampNov22/images
and ran…
docker run -ti --rm -v /home/declan/datasets:/datasets opendronemap/odm --project-path /datasets CampNov22 --dsm --pc-quality ultra --feature-quality ultra --pc-skip-geometric
Possible issues:
I did not set –min-num-features 15000 or –matcher-neighbors 20
Some images had long names…
image extensions are all caps ‘JPG’
some images and the project folder contain caps
Any ideas as to why this failed?
Many thanks,
Declan
This is the output from the logs…
“odmVersion”: “3.0.3”,
“memory”: {
“total”: 2064248,
“available”: 2044652
“cpus”: 128,
“images”: 8054,
“options”: {
“3d_tiles”: false,
“align”: null,
“auto_boundary”: false,
“auto_boundary_distance”: 0,
“bg_removal”: false,
“boundary”: {},
“build_overviews”: false,
“camera_lens”: “auto”,
“cameras”: {},
“cog”: false,
“copy_to”: null,
“crop”: 3,
“dem_decimation”: 1,
“dem_euclidean_map”: false,
“dem_gapfill_steps”: 3,
“dem_resolution”: 5,
“dsm”: true,
“dtm”: false,
“end_with”: “odm_postprocess”,
“fast_orthophoto”: false,
“feature_quality”: “ultra”,
“feature_type”: “sift”,
“force_gps”: false,
“gcp”: null,
“geo”: null,
“gps_accuracy”: 10,
“ignore_gsd”: false,
“matcher_neighbors”: 0,
“matcher_type”: “flann”,
“max_concurrency”: 128,
“merge”: “all”,
“mesh_octree_depth”: 11,
“mesh_size”: 200000,
“min_num_features”: 10000,
“name”: “CampNov22”,
“no_gpu”: false,
“optimize_disk_space”: false,
“orthophoto_compression”: “DEFLATE”,
“orthophoto_cutline”: false,
“orthophoto_kmz”: false,
“orthophoto_no_tiled”: false,
“orthophoto_png”: false,
“orthophoto_resolution”: 5,
“pc_classify”: false,
“pc_copc”: false,
“pc_csv”: false,
“pc_ept”: false,
“pc_filter”: 2.5,
“pc_las”: false,
“pc_quality”: “ultra”,
“pc_rectify”: false,
“pc_sample”: 0,
“pc_skip_geometric”: true,
“pc_tile”: false,
“primary_band”: “auto”,
“project_path”: “/datasets/CampNov22”,
“radiometric_calibration”: “none”,
“rerun”: null,
“rerun_all”: false,
“rerun_from”: null,
“rolling_shutter”: false,
“rolling_shutter_readout”: 0,
“sfm_algorithm”: “incremental”,
“skip_3dmodel”: false,
“skip_band_alignment”: false,
“skip_orthophoto”: false,
“skip_report”: false,
“sky_removal”: false,
“sm_cluster”: null,
“sm_no_align”: false,
“smrf_scalar”: 1.25,
“smrf_slope”: 0.15,
“smrf_threshold”: 0.5,
“smrf_window”: 18.0,
“split”: 999999,
“split_image_groups”: null,
“split_overlap”: 150,
“texturing_keep_unseen_faces”: false,
“texturing_single_material”: false,
“texturing_skip_global_seam_leveling”: false,
“texturing_skip_local_seam_leveling”: false,
“tiles”: false,
“use_3dmesh”: false,
“use_exif”: false,
“use_fixed_camera_params”: false,
“use_hybrid_bundle_adjustment”: false
“startTime”: “2023-01-17T13:02:34.104964”,
“stages”: [
“name”: “dataset”,
“startTime”: “2023-01-17T13:02:35.507187”,
“messages”: [
“message”: “Running dataset stage”,
“type”: “info”
“message”: “Loading dataset from: /datasets/CampNov22/images”,
“type”: “info”
“message”: “Loading 8057 images”,
“type”: “info”
“message”: “Cannot read /datasets/CampNov22/images/P150m60ol30ca_DJI_0370.JPG with PIL, fallback to cv2: cannot identify image file ‘/datasets/CampNov22/images/P150m60ol30ca_DJI_0370.JPG’”,
“type”: “warning”
“message”: “P150m60ol30ca_DJI_0370.JPG seems corrupted and will not be used”,
“type”: “warning”
“message”: “Cannot read /datasets/CampNov22/images/50m60ol30ca_v1-a_DJI_0051_1.JPG with PIL, fallback to cv2: cannot identify image file ‘/datasets/CampNov22/images/50m60ol30ca_v1-a_DJI_0051_1.JPG’”,
“type”: “warning”
“message”: “50m60ol30ca_v1-a_DJI_0051_1.JPG seems corrupted and will not be used”,
“type”: “warning”
“message”: “Cannot read /datasets/CampNov22/images/P140m60ol45ca_DJI_0201.JPG with PIL, fallback to cv2: cannot identify image file ‘/datasets/CampNov22/images/P140m60ol45ca_DJI_0201.JPG’”,
“type”: “warning”
“message”: “P140m60ol45ca_DJI_0201.JPG seems corrupted and will not be used”,
“type”: “warning”
“message”: “Wrote images database: /datasets/CampNov22/images.json”,
“type”: “info”
“message”: “Found 8054 usable images”,
“type”: “info”
“message”: “Parsing SRS header: WGS84 UTM 35N”,
“type”: “info”
“message”: “Finished dataset stage”,
“type”: “info”
“name”: “split”,
“startTime”: “2023-01-17T13:14:17.402761”,
“messages”: [
“message”: “Running split stage”,
“type”: “info”
“message”: “Normal dataset, will process all at once.”,
“type”: “info”
“message”: “Finished split stage”,
“type”: “info”
“name”: “merge”,
“startTime”: “2023-01-17T13:14:17.402919”,
“messages”: [
“message”: “Running merge stage”,
“type”: “info”
“message”: “Normal dataset, nothing to merge.”,
“type”: “info”
“message”: “Finished merge stage”,
“type”: “info”
“name”: “opensfm”,
“startTime”: “2023-01-17T13:14:17.403004”,
“messages”: [
“message”: “Running opensfm stage”,
“type”: “info”
“message”: “Maximum photo dimensions: 4056px”,
“type”: “info”
“message”: “Photo dimensions for feature extraction: 4056px”,
“type”: “info”
“message”: “nvidia-smi not found in PATH, using CPU”,
“type”: “info”
“message”: “Altitude data detected, enabling it for GPS alignment”,
“type”: “info”
“message”: [
“use_exif_size: no”,
“flann_algorithm: KDTREE”,
“feature_process_size: 4056”,
“feature_min_frames: 10000”,
“processes: 128”,
“matching_gps_neighbors: 0”,
“matching_gps_distance: 0”,
“matching_graph_rounds: 50”,
“optimize_camera_parameters: yes”,
“reconstruction_algorithm: incremental”,
“undistorted_image_format: tif”,
“bundle_outlier_filtering_type: AUTO”,
“sift_peak_threshold: 0.066”,
“align_orientation_prior: vertical”,
“triangulation_type: ROBUST”,
“retriangulation_ratio: 2”,
“matcher_type: FLANN”,
“feature_type: SIFT”,
“use_altitude_tag: yes”,
“align_method: auto”,
“local_bundle_radius: 0”
“type”: “info”
“message”: “Wrote reference_lla.json”,
“type”: “info”
“message”: “running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" detect_features "/datasets/CampNov22/opensfm"”,
“type”: “info”
“message”: “running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" match_features "/datasets/CampNov22/opensfm"”,
“type”: “info”
“message”: “running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" create_tracks "/datasets/CampNov22/opensfm"”,
“type”: “info”
“message”: “running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" reconstruct "/datasets/CampNov22/opensfm"”,
“type”: “info”
“message”: “Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 3.0.3 documentation”,
“type”: “error”
“endTime”: “2023-01-22T07:33:49.985583”,
“totalTime”: 411572.58
“processes”: [
“command”: “"/code/SuperBuild/install/bin/opensfm/bin/opensfm" detect_features "/datasets/CampNov22/opensfm"”,
“exitCode”: 0,
“output”: [
“2023-01-17 13:46:47,298 DEBUG: Found 94887 points in 5.566389799118042s”,
“2023-01-17 13:46:47,299 DEBUG: done”,
“2023-01-17 13:46:47,402 DEBUG: Found 62727 points in 4.435869455337524s”,
“2023-01-17 13:46:47,402 DEBUG: done”,
“2023-01-17 13:46:47,510 DEBUG: Found 80460 points in 5.27877950668335s”,
“2023-01-17 13:46:47,511 DEBUG: done”,
“2023-01-17 13:46:47,588 DEBUG: Found 61766 points in 4.7386720180511475s”,
“2023-01-17 13:46:47,588 DEBUG: done”,
“2023-01-17 13:46:49,784 DEBUG: Found 241235 points in 6.456133842468262s”,
“2023-01-17 13:46:49,785 DEBUG: done”
“command”: “"/code/SuperBuild/install/bin/opensfm/bin/opensfm" match_features "/datasets/CampNov22/opensfm"”,
“exitCode”: 0,
“output”: [
“2023-01-17 18:44:20,619 DEBUG: Matching 50m60ol30ca_v1-b_DJI_0185.JPG and P135m60ol70ca_DJI_0281.JPG. Matcher: FLANN (symmetric) T-desc: 52.862 T-robust: 0.018 T-total: 52.880 Matches: 147 Robust: 12 Success: False”,
“2023-01-17 18:44:20,892 DEBUG: Matching P225m60ol70ca_DJI_0164.JPG and P230m60ol45ca_DJI_0710.JPG. Matcher: FLANN (symmetric) T-desc: 100.926 T-robust: 0.019 T-total: 100.946 Matches: 215 Robust: 24 Success: True”,
“2023-01-17 18:44:21,161 DEBUG: Matching 50m60ol30ca_v1-a_DJI_0045_1.JPG and P135m60ol70ca_DJI_0975.JPG. Matcher: FLANN (symmetric) T-desc: 51.578 T-robust: 0.017 T-total: 51.596 Matches: 124 Robust: 13 Success: False”,
“2023-01-17 18:44:21,521 DEBUG: Matching P340m60ol45ca_DJI_0776.JPG and P335m60ol70ca_DJI_0203.JPG. Matcher: FLANN (symmetric) T-desc: 3.161 T-robust: 0.002 T-total: 3.164 Matches: 493 Robust: 364 Success: True”,
“2023-01-17 18:44:21,589 DEBUG: Matching P140m60ol45ca_DJI_0554.JPG and 50m60ol30ca_v1-b_DJI_0691_1.JPG. Matcher: FLANN (symmetric) T-desc: 60.018 T-robust: 0.022 T-total: 60.041 Matches: 432 Robust: 218 Success: True”,
“2023-01-17 18:44:22,109 DEBUG: Matching 50m60ol30ca_v1-a_DJI_0200.JPG and 50m60ol30ca_v1-b_DJI_0105_2.JPG. Matcher: FLANN (symmetric) T-desc: 1.487 T-robust: 0.010 T-total: 1.497 Matches: 129 Robust: 71 Success: True”,
“2023-01-17 18:44:22,360 DEBUG: Matching P135m60ol70ca_DJI_0335.JPG and P135m60ol70ca_DJI_0644.JPG. Matcher: FLANN (symmetric) T-desc: 101.663 T-robust: 0.005 T-total: 101.669 Matches: 497 Robust: 327 Success: True”,
“2023-01-17 18:44:24,745 DEBUG: Matching P135m60ol70ca_DJI_0301.JPG and P140m60ol45ca_DJI_0393.JPG. Matcher: FLANN (symmetric) T-desc: 65.615 T-robust: 0.020 T-total: 65.637 Matches: 295 Robust: 104 Success: True”,
“2023-01-17 18:45:00,511 DEBUG: Matching P135m60ol70ca_DJI_0007.JPG and P135m60ol70ca_DJI_0939.JPG. Matcher: FLANN (symmetric) T-desc: 108.210 T-robust: 0.019 T-total: 108.230 Matches: 286 Robust: 52 Success: True”,
“2023-01-17 18:45:00,680 INFO: Matched 88503 pairs (brown-brown: 88503) in 17866.780273348006 seconds (0.20187767962496184 seconds/pair).”
“command”: “"/code/SuperBuild/install/bin/opensfm/bin/opensfm" create_tracks "/datasets/CampNov22/opensfm"”,
“exitCode”: 0,
“output”: [
“2023-01-17 19:06:12,183 INFO: reading features”,
“2023-01-17 19:39:50,274 DEBUG: Merging features onto tracks”,
“2023-01-17 19:53:57,935 DEBUG: Good tracks: 53994633”
“command”: “"/code/SuperBuild/install/bin/opensfm/bin/opensfm" reconstruct "/datasets/CampNov22/opensfm"”,
“exitCode”: 134,
“output”: [
“2023-01-22 06:57:55,070 INFO: Adding 50m60ol30ca_v1-b_DJI_0041_2.JPG to the reconstruction”,
“2023-01-22 06:58:40,115 INFO: -------------------------------------------------------”,
“2023-01-22 06:58:40,167 INFO: 50m60ol30ca_v1-b_DJI_0039_2.JPG resection inliers: 944 / 981”,
“2023-01-22 06:58:40,218 INFO: Adding 50m60ol30ca_v1-b_DJI_0039_2.JPG to the reconstruction”,
“2023-01-22 06:59:25,356 INFO: -------------------------------------------------------”,
“2023-01-22 06:59:25,404 INFO: 50m60ol30ca_v1-b_DJI_0037_2.JPG resection inliers: 1059 / 1164”,
“2023-01-22 06:59:25,461 INFO: Adding 50m60ol30ca_v1-b_DJI_0037_2.JPG to the reconstruction”,
“2023-01-22 06:59:26,626 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.”,
“block_sparse_matrix.cc:80 Check failed: num_nonzeros_ >= 0”,
“/code/SuperBuild/install/bin/opensfm/bin/opensfm: line 12: 801 Aborted (core dumped) "$PYTHON" "$DIR"/opensfm_main.py "[email protected]"”
“success”: false,
“error”: {
“code”: 134,
“message”: “Child returned 134”
“stackTrace”: [
“Traceback (most recent call last):”,
“File "/code/stages/odm_app.py", line 81, in execute”,
“self.first_stage.run()”,
“File "/code/opendm/types.py", line 386, in run”,
“self.next_stage.run(outputs)”,
“File "/code/opendm/types.py", line 365, in run”,
“self.process(self.args, outputs)”,
“File "/code/stages/run_opensfm.py", line 38, in process”,
“octx.reconstruct(args.rolling_shutter, self.rerun())”,
“File "/code/opendm/osfm.py", line 55, in reconstruct”,
“self.run(‘reconstruct’)”,
“File "/code/opendm/osfm.py", line 34, in run”,
“system.run(‘"%s" %s "%s"’ %”,
“File "/code/opendm/system.py", line 110, in run”,
“raise SubprocessException("Child returned {}".format(retcode), retcode)”,
“opendm.system.SubprocessException: Child returned 134”,
“totalTime”: 412275.88
