I Tried WEBODM using AWS server
inside the Putty it is showing the WEBODM is started
i can also see the status of the usage…
but i cannot able to access the webpage with the port and the public DNS ip
Probably a firewall/network configuration issue on AWS. Check that port 8000 is available from the outside.
yes it is open…
i checked
i’ve used the public ip of the machine with 8000 as port as well as 3000 i tried
Hi
any update on the same
Here are some instructions that helped me a Lot:
Things you should double check on AWS: port 8000, public ip access
