Awesome 3d results
hello,
finally i’ve gotten a better result in 2d processing on webodm vs precisionmapper and with 3d texturing a similar result between webodm and precionmapper. Precisionmapper didn’t calculate the gps coordinates correctly to georectify the images.
Awesome work guys:
precisionmapper 2d:
precisionmapper 3dt:
webodm 2d:
webodm 3dt:
Carlos
Looks great! How did you get results from under the bridge? Could you outline your workflow and which software you use for flightplanning?
Hey, I just want to know what is your gear, flight planning application and parameter settings that was used?
hello,
I did 2 flights:
1 - grid like with north south heading @ 35m AGL ;
2 - a circular flight @15m AGL;
The photos were processed on WEBODM with the 3dmodel setting.
Thanks for asking.
The settings are described on the previous answer.
The kit is a DJI Phantom3 Advanced
Thanks for asking.
Carlos
Hello!
This last image was used in the webodm.net website. I would like, at least, to be credited for the work … image
Hmm, yup: @pierotofy.
:pray: added. Apologies @carlozousa!
No apologies needed! you guys are awesome!! Thank you!
BTW: Have also been working on creating a showcase, and in the case of this image, here is the link!
https://matrix.thegreenislandproject.com:44300/public/task/4e12ba6f-1ef9-4918-b827-b772e98fb0ad/map/
