I am working with this in Azure, would it work to setup autoscaling with conf file in Azure. Or does ODM just natively support the cloud vendors mentioned?
Otherwise it would be worth a try!
Best Regards,
reduards
Best Regards,
reduards
Just thought from my side, wouldnt it be possible to put the nodes on Kubernetes cluster with a load balancer in front? I guess parallel execution would not work then however.
EDIT:
Found this link with a project/fork for Kubernetes cluster regarding WebODM and NodeODM:
WEBODM Kubernetes - WebODM - OpenDroneMap Community
Would just be interesting to know how the setup is now, is like a VM scale set in AWS or do you just have script spinning up a vm and installing docker then running the image? Any documentation regarding the cluster autoscaling setup?
Best Regards,
Rasmus
