Autoscale using ODM
Does autoscale of clusterodm using aws config file work with parameter --sm-cluster in the native odm. I tried using this but am facing an issue that I have mentioned here.
So you’re trying to autoscale in a local/native cluster not on AWS?
Thank you Saijin for the reply. My issue is solved now and i was using wrong endpoint in the config file and i was using aws autoscale
