Areas missing
I am new to the community. I processed a map with 100 images. All went fine - BUT… about 2/3 of the acutal area that are represented in the images is missing in the final orthomap…
Is there a setting to force pictures to end up in the map or to deactivate the removing of areas after “stitching”?
Thank you!
Kevin
Hey @wellsforzoe :hand: you can use --crop 0 to skip cropping. Also if a large area is missing, it’s probably because not enough features were found. Increase --min-num-features as well (double the default value).
