Applying a shapefile
Thank you for the fantastic script, I have run a image set through your script and saved the shapefile but I’ve had a additional image to analyse. Ive loaded the shapefile ShapeFile <- readOGR("Other_Software_ShapeFile.shp") how do I apply the shapefile to the image
Hi Jason,
I am not sure if I understood your question, but please see if this code helps:
plotRGB(RGB.rescale(Ex.Mosaic,3))
plot(ShapeFile, add=T)
All the best,
Filipe
