If I run one single job on ClusterODM, it comes back clean and quick. However, if I run 2 or more jobs simultaneously on ClusterODM, some jobs fail due to I/O errors and/or others will finish, but the orthophoto will contain multiple anomalies. These can be patches where the scale is off, or the orientation is wrong… It almost like the parent node received the wrong patch from a child node, but is forcing the merge as best it can. Has anyone else experienced this issue?
