Annotations is not editable
Hello! Tested annotations instrument - when I try to add some in 3D mode: point cloud or 3d model - it creates with deafault text and after there is now opportunity to edit it:(
Saw here the same issue dated 2021. Could that problem be solved?
Thanks for confirming the bug!
Can you tell us more about about what version of WebODM you’re using?
What are you labelling?
Thank you !
WebODM 2.0.2
updated it via console a day ago
Sorry, didn’t get the question. Labeling a point in point cloud or point in 3d model. It is just an example on the screen.
After you click Annotation then on somewhere on the model - it create default annotation and no opportunity to edit it :frowning:
Hi Saijin! Thank you for help! Can you close the topic. Problem solcved - it is my fault. It is not obvious how to edit Annotations))
For others - you need to do it in Scene section - Annotations - Propperties section (at the bottom of left menu)
