From @Gregoriomartjim on Thu Jul 06 2017 18:44:20 GMT+0000 (UTC)
Hello
I have some photos with georeference. i used opendronemap to get the point cloud but i cant get the point clouds aligned, (i used the altitude, latitude and longitude) however i cant manage to align them.
Is there a way to do this or am i doing something wrong?
Is there a way to set the origin in opendronemap?
this is a picture of the 2 point cluods
Regards
Copied from original issue: aligning two point clouds using georeference · Issue #623 · OpenDroneMap/ODM · GitHub
From @dakotabenjamin on Tue Jul 11 2017 19:10:51 GMT+0000 (UTC)
A naive alignment will not likely work in this case. ODM currently does not have this functionality. So are these two point clouds encompassing the same area? I’m not sure exactly what I’m looking at
From @Gregoriomartjim on Tue Jul 11 2017 19:22:24 GMT+0000 (UTC)
yes they are the same area, but different pictures. They look to have the same plane orientation, but one is above the other.
From @dakotabenjamin on Tue Jul 11 2017 19:42:28 GMT+0000 (UTC)
OK, I think this is outside the scope of ODM, so I will close this issue.
From @yjmenezes on Tue Jul 11 2017 20:46:51 GMT+0000 (UTC)
@dakotabenjamin , i apologise, let me reopen this issue.
@Gregoriomartjim
it is interesting, to compare same area at different time. ( temporal analysis )
Could you, please, share your command line options and your “logs” , and gcp_list.txt, if available ?
From @Gregoriomartjim on Tue Jul 11 2017 20:56:05 GMT+0000 (UTC)
well i got the GPS coordinates from a different sensor, then using exiftool i add the coordinates to the pictures, finally i used this in ODM. how could i upload the pictures ?
From @yjmenezes on Tue Jul 11 2017 22:20:47 GMT+0000 (UTC)
@Gregoriomartjim
you can create a new repo and upload your images.
Git has a 25MB limit for upload.
compress your images using several blocks if necessary.
From @Gregoriomartjim on Tue Jul 11 2017 23:15:09 GMT+0000 (UTC)
https://github.com/Gregoriomartjim/gps-pictures ok i put the images here, i use the first 5 for one map and the next 5 for the second map, thanks for the answers
