Align problem
I want to use --align with a geotiff but the alignment failed with this error
[WARNING] Alignment to /foo/bar/gile_ortho.tif will be skipped
more info here Align Problem ? · Issue #1607 · OpenDroneMap/ODM · GitHub
Is the align function already available ?
ODM version is 3.0.4 from latest docker image
What are you using as your alignment GeoTIFF?
I wanted to use a previous odm_ortho.tiff file.
But I was advised that I should use instead the odm_dem.tif.
