Hello, I accidentally unistalled docker and could not start webodm so I installed again together with Virtual Machine but still I can´t connect, I got this message:
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Initializing console…
OpenSSH check passed
Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host “192.168.99.100:2376”: dial tcp 192.168.99.100:2376: connectex: No connection could be made because the target machine actively refused it.
You can attempt to regenerate them using ‘docker-machine regenerate-certs [name]’.
Be advised that this will trigger a Docker daemon restart which might stop running containers.
Need to regenerate certificates
Regenerating TLS certificates
Waiting for SSH to be available…
Detecting the provisioner…
webodm - virtualbox Running tcp://192.168.99.100:2376 Unknown Unable to query docker version: Get https://192.168.99.100:2376/v1.15/version: dial tcp 192.168.99.100:2376: connectex: No connection could be made because the target machine actively refused it.
Unable to verify the Docker daemon is listening: Maximum number of retries (10) exceeded
Please help?
