i feel like the UAV Arena github page hasnt really been updated in a while now, since a newer version of odm is available, shall i add results from the latest version of odm for the sake of comparison ?
I don’t know that we’ve made any changes that should improve/change the output, but if you’d like to create those products and compare, please do so!
Yep, we’d welcome a pull request!
thank you for your support
just to clarify, i would just process the projects in default mode without making any changes or compressing anything right?
These results have been processed for each software using using “medium quality” / default settings, 2 cm/px resolution (if it was available, otherwise highest allowed).
From the “Info” on https://opendronemap.github.io/UAVArena/
update. i now have the desired amount of ram to run odm successfully and i forked the repository to add the newest odm version’s data for comparison. when i open the data in the folder named odm 0.9.9 i fail to understand as to where i must get these files from for the newest version of odm.
Ive processed the data set and i downloaded all the assets. please guide me so i can generate a pull request
Use the —tiles option to generate the tiles for a dataset.
I’m doing this, the process is underway. i had a quick question. the results wont come out badly because im using my PC at the same time to attend online class right? im only asking this because its for bench-marking purposes and i want to do it some justice.
Correct, it won’t affect quality of results.
ive generated a pull request, please look into it. i will be awaiting your feedback
Thank you for your contributions in the odm-benchmarks repo, as well!
It’s an honor
