Accidently filled hard drive with projects
cant log in to my server now that I filled the hard drive with projects. gonna use usb os to delete projects off the drive but unsure of where they are located. linux webodm, thanks for help.
Should be in one of various docker volumes.
I think you should be able to chroot into the OS from the Recovery drive, and then access the docker terminal from there…
I have not tried this, however.
I was able to start a terminal from the login screen and purge docker. reinstalled webodm and made sure to put media dir on a large data drive rather than OS drive. Thanks
