Hi there!,
Im using WebODM and is quite nice but I have hardware limitations and I though the lighting will be my solution. Then I used the lighting node to process some task and was nice but I can't get really orthomaps nor 3D models with good quality because the lighting node has some settings limitations like: depthmap-resolution... and other things that can
t allow similar results like dronedeploy in that kind of works.
¿are there any options to get that high quality results with WebODM? I know get a better hardware but this is more expensive that pay for Dronedeploy.
Thanks for your comments.
