Hi! I have large amounts of sd copies on my hard disk, usually, a mission generates 4 to 5 directories due to the 999 files limit plus a dir for each sd card. Is there any way that Dronedb read both dirs and shows them together instead of opening one and after the other? As well as shows all images of all sub dirs to have a real notion of my catalog. Thanks in advance.
We don’t have a means to do that quite yet, but you might instead benefit from the workflow of using a tool like ReNamer by den4b to rename the files using their EXIF datetime into unique filenames that can then be easily combined without worry of name collisions.
