I created a 3D mapping mission and completed the mission. After using WebODM to process the photos I’m noticing some distortion of a statue in the 3D model. What can cause this? I used an air 2s with a single grid and orbit as suggested in a tutorial here: Dronelink Advanced #07 - Mapping - YouTube . Speed: 16mph, overlap was 75% front and 70% side. Gimbal pitch was -75deg. Capture interval was 2 seconds while I think I accidentally had the orbit interval set at 4 seconds.
We recommend higher overlap/sidelap for 3D modeling, usually 85% or greater.
What does the point cloud look like? Is it reasonably clean/well-formed? If so, you might need to increase your mesh quality parameters (--mesh-size
and --mesh-octree-depth
