hello, Thank you for your program, I want to do well on this program, and I need a lot of study.
2D model is made, but 3D model is not allowed. I need your help.
thanks.
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --points “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm”
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --transformation --proj ‘+proj=utm +zone=52 +datum=WGS84 +units=m +no_defs +type=crs’ “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm”
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_openmvs “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm”
[WARNING] Legacy option --depthmap-resolution (this might be removed in a future version). Use --pc-quality instead.
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 0 --min-resolution 1000 --max-resolution 1000 --max-threads 4 -w “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/depthmaps” -v 0
13:25:58 [App ] Build date: Dec 7 2020, 14:22:34
13:25:58 [App ] CPU: Intel(R) Core™ i7-8565U CPU @ 1.80GHz (4 cores)
13:25:58 [App ] RAM: 9.28GB Physical Memory 3.21GB Virtual Memory
13:25:58 [App ] OS: Linux 4.19.130-boot2docker (x86_64)
13:25:58 [App ] SSE & AVX compatible CPU & OS detected
13:25:58 [App ] Command line: /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene.mvs --resolution-level 0 --min-resolution 1000 --max-resolution 1000 --max-threads 4 -w /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/depthmaps -v 0
13:25:58 [App ] Preparing images for dense reconstruction completed: 16 images (101ms)
13:25:58 [App ] Selecting images for dense reconstruction completed: 16 images (49ms)
Estimated depth-maps 1 (6.25%, 26s, ETA 6m)…
Estimated depth-maps 2 (12.50%, 56s, ETA 6m)…
Estimated depth-maps 3 (18.75%, 1m27s, ETA 6m)…
Estimated depth-maps 4 (25.00%, 1m57s, ETA 5m)…
Estimated depth-maps 5 (31.25%, 2m29s, ETA 5m)…
Estimated depth-maps 6 (37.50%, 3m1s, ETA 5m)…
Estimated depth-maps 7 (43.75%, 3m33s, ETA 4m)…
Estimated depth-maps 8 (50.00%, 4m9s, ETA 4m)…
Estimated depth-maps 9 (56.25%, 4m42s, ETA 3m)…
Estimated depth-maps 10 (62.50%, 5m16s, ETA 3m)…
Estimated depth-maps 11 (68.75%, 5m51s, ETA 2m)…
Estimated depth-maps 12 (75.00%, 6m25s, ETA 2m)…
Estimated depth-maps 13 (81.25%, 7m, ETA 1m)…
Estimated depth-maps 14 (87.50%, 7m37s, ETA 1m)…
Estimated depth-maps 15 (93.75%, 8m10s, ETA 32s)…
Estimated depth-maps 16 (100.00%, 8m44s, ETA 0ms)…
Estimated depth-maps 16 (100%, 8m44s159ms)
Filtered depth-maps 1 (6.25%, 4s, ETA 1m)…
Filtered depth-maps 5 (31.25%, 4s, ETA 10s)…
Filtered depth-maps 9 (56.25%, 5s, ETA 4s)…
Filtered depth-maps 12 (75.00%, 5s, ETA 1s)…
Filtered depth-maps 14 (87.50%, 5s, ETA 772ms)…
Filtered depth-maps 16 (100.00%, 5s, ETA 0ms)…
Filtered depth-maps 16 (100%, 5s519ms)
Fused depth-maps 0 (0.00%, 1s, ETA 0ms)…
Fused depth-maps 1 (6.25%, 1s, ETA 26s)…
Fused depth-maps 2 (12.50%, 1s, ETA 13s)…
Fused depth-maps 3 (18.75%, 2s, ETA 10s)…
Fused depth-maps 6 (37.50%, 2s, ETA 4s)…
Fused depth-maps 9 (56.25%, 2s, ETA 2s)…
Fused depth-maps 11 (68.75%, 3s, ETA 1s)…
Fused depth-maps 16 (100%, 3s350ms)
13:34:51 [App ] Densifying point-cloud completed: 1336307 points (8m53s475ms)
13:34:58 [App ] MEMORYINFO: {
13:34:58 [App ] VmPeak: 1209952 kB
13:34:58 [App ] VmSize: 1182144 kB
13:34:58 [App ] } ENDINFO
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud --filter-point-cloud -1 -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene_dense.mvs” -v 0
13:34:59 [App ] Build date: Dec 7 2020, 14:22:34
13:34:59 [App ] CPU: Intel(R) Core™ i7-8565U CPU @ 1.80GHz (4 cores)
13:34:59 [App ] RAM: 9.28GB Physical Memory 3.21GB Virtual Memory
13:34:59 [App ] OS: Linux 4.19.130-boot2docker (x86_64)
13:34:59 [App ] SSE & AVX compatible CPU & OS detected
13:34:59 [App ] Command line: --filter-point-cloud -1 -i /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene_dense.mvs -v 0
Point visibility checks 179205 (13.41%, 3s, ETA 19s)…
Point visibility checks 331794 (24.83%, 6s, ETA 18s)…
Point visibility checks 491418 (36.77%, 9s, ETA 15s)…
Point visibility checks 670540 (50.18%, 12s, ETA 11s)…
Point visibility checks 828427 (61.99%, 15s, ETA 9s)…
Point visibility checks 978285 (73.21%, 18s, ETA 6s)…
Point visibility checks 1071963 (80.22%, 21s, ETA 5s)…
Point visibility checks 1153461 (86.32%, 24s, ETA 3s)…
Point visibility checks 1238053 (92.65%, 27s, ETA 2s)…
Point visibility checks 1316076 (98.49%, 30s, ETA 461ms)…
Point visibility checks 1336307 (100%, 30s982ms)
13:35:37 [App ] MEMORYINFO: {
13:35:37 [App ] VmPeak: 510288 kB
13:35:37 [App ] VmSize: 494628 kB
13:35:37 [App ] } ENDINFO
[INFO] Finished openmvs stage
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene_dense_dense_filtered.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] Splitting point cloud filtering in chunks of 250000 vertices
[INFO] running pdal split -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/openmvs/scene_dense_dense_filtered.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part.ply” --capacity 250000 --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar”
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_3.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_1.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_6.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_4.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_6.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_6_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_4.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_4_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_1.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_1_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_3.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_3_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_5.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_5.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_5_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] Filtering /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_2.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_2.ply” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/parts/part_2_filtered.ply” outlier range --writers.ply.sized_types=false --writers.ply.storage_mode=‘little endian’ --writers.ply.dims=“x=float,y=float,z=float,nx=float,ny=float,nz=float,red=uchar,blue=uchar,green=uchar” --filters.outlier.method=‘statistical’ --filters.outlier.mean_k=16 --filters.outlier.multiplier=2.5 --filters.range.limits=‘Classification![7:7]’
[INFO] Merging 6 point cloud chunks to /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/point_cloud.ply
[INFO] Writing ODM Mesh file in: /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_meshing/odm_mesh.ply
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/point_cloud.ply --out /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_meshing/odm_mesh.dirty.ply --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 3 --linearFit
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_meshing/odm_mesh.dirty.ply -outputFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 300000
[INFO] Finished odm_meshing stage
[INFO] Running mvs_texturing stage
[INFO] Writing MVS Textured file in: /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_texturing/odm_textured_model.obj
[INFO] running /code/SuperBuild/install/bin/texrecon /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/undistorted/reconstruction.nvm /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_meshing/odm_mesh.ply /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none --no_intermediate_results
/code/SuperBuild/install/bin/texrecon (built on Dec 7 2020, 14:07:55)
Load and prepare mesh:
Reading PLY: 299679 verts…
599162 faces…
done.
Warning: Zero-length normals detected: 50 face normals, 0 vertex normals
Generating texture views:
NVM: Loading file…
NVM: Number of features: 25631
Loading 100%… done. (Took 0.174s)
Building adjacency graph:
Adding edges 100%… done. (Took 2.475s)
898650 total edges.
View selection:
Building BVH from 599162 faces…
done. (Took: 1353 ms)
Calculating face qualities 100%… done. (Took 9.626s)
Postprocessing face infos 100%… done. (Took 2.306s)
Maximum quality of a face within an image: 290
Clamping qualities to 3.21933 within normalization.
Optimizing:
Time[s] Energy
1 525337
3 510163
4 504886
5 501603
7 500069
9 499196
10 498647
12 497969
14 497648
15 497438
16 497302
17 497186
19 497094
20 496996
12466 faces have not been seen
Took: 35.604s
Generating texture patches:
Running…
done. (Took 1.187s)
772 texture patches.
Running global seam leveling:
done.
Lhs dimensionality: 311196 x 311196
Calculating adjustments:
Color channel 0: CG took 79 iterations. Residual is 9.34324e-05
Color channel 2: CG took 79 iterations. Residual is 9.6917e-05
Color channel 1: CG took 79 iterations. Residual is 8.84714e-05
Took 1.362 seconds
Adjusting texture patches 100%… done. (Took 0.253s)
Running local seam leveling:
Blending texture patches 100%… done. (Took 4.647s)
Generating texture atlases:
Sorting texture patches…
done.
Working on atlas 1 100%… done.
Finalizing texture atlases…
done. (Took: 14.36s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 72.602s
[INFO] Running georeferencing with OpenSfM transformation matrix
[INFO] running /code/build/bin/odm_georef -bundleFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/bundle_r000.out -inputTransformFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/opensfm/geocoords_transformation.txt -inputCoordFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/coords.txt -inputFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_texturing/odm_textured_model.obj -outputFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_texturing/odm_textured_model_geo.obj -inputPointCloudFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_filterpoints/point_cloud.ply -outputPointCloudFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.laz -outputPointCloudSrs ‘+proj=utm +zone=52 +datum=WGS84 +units=m +no_defs +type=crs’ -logFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferencing_log.txt -outputTransformFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferencing_transform.txt -georefFileOutputPath /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Calculating cropping area and generating bounds shapefile from point cloud
[INFO] running pdal translate -i “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.laz” -o “/var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.decimated.las” decimation --filters.decimation.step=40
[INFO] running pdal info --boundary --filters.hexbin.edge_size=1 --filters.hexbin.threshold=0 /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.decimated.las > /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.boundary.json
[INFO] running pdal info --summary /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.laz > /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.summary.json
[INFO] running ogr2ogr -overwrite -f GPKG -a_srs “+proj=utm +zone=52 +datum=WGS84 +units=m +no_defs” /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.bounds.gpkg /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.bounds.geojson
[INFO] Running odm_dem stage
[WARNING] Maximum resolution set to GSD - -300% (5.3 cm / pixel, requested resolution was 5 cm / pixel)
[INFO] Classify: False
[INFO] Create DSM: False
[INFO] Create DTM: False
[INFO] DEM input file /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.laz found: True
[INFO] Finished odm_dem stage
[INFO] running /code/build/bin/odm_orthophoto -inputFiles /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_texturing/odm_textured_model_geo.obj -logFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto_log.txt -outputFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto_render.tif -resolution 20.0 -outputCornerFile /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto_corners.txt
[INFO] Creating GeoTIFF
[INFO] running gdal_translate -a_ullr 302126.4397778349 3886963.830855474 302172.9013848143 3886917.3692484945 -co TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=2 -co BIGTIFF=IF_SAFER -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co NUM_THREADS=4 -a_srs “+proj=utm +zone=52 +datum=WGS84 +units=m +no_defs +type=crs” --config GDAL_CACHEMAX 43.4% --config GDAL_TIFF_INTERNAL_MASK YES /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto_render.tif /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto.tif > /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/gdal_translate_log.txt
[INFO] Cropping /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto.tif
[INFO] running gdalwarp -cutline /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_georeferencing/odm_georeferenced_model.bounds.gpkg -crop_to_cutline -co TILED=YES -co COMPRESS=DEFLATE -co PREDICTOR=2 -co BIGTIFF=IF_SAFER -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co NUM_THREADS=4 -dstalpha /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto.original.tif /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto.tif --config GDAL_CACHEMAX 43.4%
Using band 4 of source image as alpha.
Creating output file that is 519P x 747L.
Processing /var/www/data/6f4134cb-69f9-45b4-8625-8ec7d0dbbd5c/odm_orthophoto/odm_orthophoto.original.tif [1/1] :
Entwine is not installed, checking if PotreeConverter is available instead…
PotreeConverter is also not installed, will skip generation of Potree point cloud
Compressing all.zip
Done!
