1st time setup, Docker not Starting
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Detected Windows 10 with Hyper-V support
Initializing console…
error during connect: In the default daemon configuration on Windows, the docker client must be run with elevated privileges to connect.: Get “http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.24/containers/json”: open //./pipe/docker_engine: The system cannot find the file specified.
Attempting to start Docker…
Waiting for Docker… 1
Waiting for Docker… 2
Waiting for Docker… 3
Waiting for Docker… 4
Waiting for Docker… 5
Waiting for Docker… 6
Waiting for Docker… 7
Waiting for Docker… 8
Waiting for Docker… 9
Waiting for Docker… 10
Waiting for Docker… 11
Waiting for Docker… 12
Waiting for Docker… 13
Waiting for Docker… 14
Waiting for Docker… 15
Waiting for Docker… 16
Waiting for Docker… 17
Waiting for Docker… 18
Waiting for Docker… 19
Waiting for Docker… 20
Waiting for Docker… 21
Waiting for Docker… 22
Waiting for Docker… 23
Waiting for Docker… 24
Waiting for Docker… 25
Docker couldn’t be started. Please try to start Docker manually and take note of any error message that might appear. Then check the installation manual for possible troubleshooting steps.
Can you try running the WebODM program again, but this time elevated as admin (right click, run as Administrator)
Also, try to manually start Docker Desktop. Do you get an error message? (If so, which is it?)
I restarted the Docker and deleted everything. Then WebODM started loading. Now it is “Waiting for WebODM” for a very long time. (which I think is normal).
I got the WebODm to run and did my first mosaic. But then I shut it all down for the night and closed docker and Webodm. But now it does not restart. DO I have to repeat the same process to get docker running all over again? or do I leave docker “running” the entire time in the background now?
Was I meant to Save my Docker Image?
I restarted everything from scratch, I purged my docker. and reran the Webodm, and got the console up. reloading and reprocessing my images. So how do I save my settings for a fast restart next time?
