Win10 WebODM Docker installation - no worker node
I’m starting with OpenDroneMap and WebODM right now.
I did the docker installation as showed in in GitHub. I think everything is fine and i can start the web UI. The problem is: The internal worker is not referenced by default. And it is not possible to connect to it manually.
What i already tried: Connecting to the ip:3000 with the Webbrowser. Also no chance to get contact to the worker. The docker-compose seems to work corretly. I found no error messages.
Is there anything more i can try?
I tried same installation process on macOS and everything works super smooth.
I’m looking forward to your answers!
With best regards
