Why I have the issue of " Child returned 137"
this is issue picture
WX20180715-163152%402x
command:
docker run -it --rm \
-v $(pwd)/images:/code/images \
-v $(pwd)/odm_orthophoto:/code/odm_orthophoto \opendronemap/opendronemap
–texturing-skip-visibility-test
I use docker
memory:8G
picture counts:224
dimensions: 4000 x 3000
I want to know why I have this issue?
Note the Killed text in the error message. That means you ran out of memory!
Try resizing your images, or if you just need an orthophoto, try to use the --fast-orthophoto parameter.
