webODM won't start trying to regen certificates (Fixed)
Hi there, webODM seems unable to start, it endlessly keeps trying to regenerate certificates. I tried to regenerate Certs through maintenance but I got the same result. Also, I tried to update, but it gave me a cod1 error…
My console msg:
Detected Windows 10 with Hyper-V support
Initializing console…
Checking Hyper-V status…
Hyper-V is enabled
Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host “192.168.1.122:2376”: x509: certificate is valid for 127.0.0.1, 192.168.1.12, not 192.168.1.122
You can attempt to regenerate them using ‘docker-machine regenerate-certs [name]’.
Be advised that this will trigger a Docker daemon restart which might stop running containers.
Need to regenerate certificates
Regenerating TLS certificates
Waiting for SSH to be available…
webodm - hyperv Running tcp://192.168.1.122:2376 Unknown Unable to query docker version: Get https://192.168.1.122:2376/v1.15/version: x509: certificate is valid for 127.0.0.1, 192.168.1.12, not 192.168.1.122
Too many retries waiting for SSH to be available. Last error: Maximum number of retries (60) exceeded
Fixed.
  • Reinstalled webodm manager (v.1.55)
  • Got an empty containers issue, tried to create them but had connection issue
  • Changed dockers DNS to fixed 8.8.8.8
  • Done! Up and running
