Webodm installer standar version loop docker default detected
Hello, buy and install the basic version without problems, but then I think I deleted a directory that needed the application, in order to reinstall everything, but now I’m in a loop that says it finds a machine in default docker, if I want to remove it, I do, start, but I get this message every time I start the WEBODM service. any clue???
a default docker machine was found…
Sent you a private message with the latest version of the installer. Try to install that, see if it fixes the problem.
