Settings for Sequioa cam (NIR-RE) for DTM/DSM
Hi there, I’m experiencing a “Process exited with code 1” error while trying to obtain a DTM/DSM from jpg images taken with Sequoia. Tried some suggestion written here on the forum to customise the default settings (min-max features, check for RAM or CPU or uptdates problems) but none seemed to work (maybe my knowledge is too basic). Can anyone help?
I’m using iOS 10.13.5, 16 GB RAM, Intel HD Graphics 3000 512 MB
here’s the link for the pics https://www.dropbox.com/sh/zvj0oevxkwa2tuq/AADMUzh9lZgkCynWPJ6Fvseua?dl=0
Here’s the task output (from 10 pictures but comes out the same with 157 pics runned the first time but here don’t pasted), thanks in advance for any reply (even addressing to useful topics not seen):
[DEBUG] Loading dataset from: /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/images
[DEBUG] /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/images
[WARNING] Could not find ccd_width in file. Use --force-ccd or edit the sensor_data.json file to manually input ccd width
[DEBUG] Loaded IMG_180810_090020_0031_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7156859958 | lon: 8.64659538376 | alt: 454.494085923
[DEBUG] Loaded IMG_180810_090015_0028_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7159491803 | lon: 8.64651123159 | alt: 455.321373892
[DEBUG] Loaded IMG_180810_090006_0025_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7162084805 | lon: 8.64646456746 | alt: 456.432160487
[DEBUG] Loaded IMG_180810_090023_0032_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7156018238 | lon: 8.64662776439 | alt: 454.229142845
[DEBUG] Loaded IMG_180810_090004_0024_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7161974416 | lon: 8.64657619738 | alt: 456.562872216
[DEBUG] Loaded IMG_180810_090012_0026_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7161167843 | lon: 8.64643310257 | alt: 455.636794559
[DEBUG] Loaded IMG_180810_090019_0030_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7157756734 | lon: 8.64656809579 | alt: 454.792372094
[DEBUG] Loaded IMG_180810_090017_0029_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7158623156 | lon: 8.64654221605 | alt: 455.068387287
[DEBUG] Loaded IMG_180810_090026_0033_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7155780828 | lon: 8.6465046167 | alt: 453.965660064
[DEBUG] Loaded IMG_180810_090013_0027_RGB.JPG | camera: parrot sequoia | dimensions: 4608 x 3456 | focal: 4.88000013735 | ccd: None | lat: 40.7160331603 | lon: 8.64647521889 | alt: 455.497916996
[INFO] Found 10 usable images
[DEBUG] running /code/build/bin/odm_extract_utm -imagesPath /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/images/ -imageListFile /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/img_list.txt -outputCoordFile /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/odm_georeferencing/coords.txt -logFile /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/odm_georeferencing/odm_georeferencing_utm_log.txt
[DEBUG] Line: WGS84 UTM 32N
[INFO] Running ODM Load Dataset Cell - Finished
[INFO] Running ODM OpenSfM Cell
[DEBUG] Altitude data detected, enabling it for GPS alignment
[DEBUG] [‘use_exif_size: no’, ‘feature_process_size: 2048’, ‘feature_min_frames: 8000’, ‘processes: 2’, ‘matching_gps_neighbors: 8’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 640’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘use_altitude_tag: True’, ‘align_method: naive’]
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/opensfm
2018-09-26 21:24:18,916 INFO: Extracting EXIF for IMG_180810_090020_0031_RGB.JPG
2018-09-26 21:24:19,164 INFO: Extracting EXIF for IMG_180810_090015_0028_RGB.JPG
2018-09-26 21:24:19,422 INFO: Extracting EXIF for IMG_180810_090006_0025_RGB.JPG
2018-09-26 21:24:19,668 INFO: Extracting EXIF for IMG_180810_090023_0032_RGB.JPG
2018-09-26 21:24:19,897 INFO: Extracting EXIF for IMG_180810_090004_0024_RGB.JPG
2018-09-26 21:24:20,148 INFO: Extracting EXIF for IMG_180810_090012_0026_RGB.JPG
2018-09-26 21:24:20,443 INFO: Extracting EXIF for IMG_180810_090019_0030_RGB.JPG
2018-09-26 21:24:20,675 INFO: Extracting EXIF for IMG_180810_090017_0029_RGB.JPG
2018-09-26 21:24:20,907 INFO: Extracting EXIF for IMG_180810_090026_0033_RGB.JPG
2018-09-26 21:24:21,143 INFO: Extracting EXIF for IMG_180810_090013_0027_RGB.JPG
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm detect_features /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/opensfm
2018-09-26 21:24:22,546 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090020_0031_RGB.JPG
2018-09-26 21:24:23,057 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090015_0028_RGB.JPG
2018-09-26 21:24:28,469 DEBUG: Found 10467 points in 5.31549191475s
2018-09-26 21:24:28,997 DEBUG: Found 10585 points in 5.33244895935s
2018-09-26 21:24:29,978 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090006_0025_RGB.JPG
2018-09-26 21:24:30,524 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090023_0032_RGB.JPG
2018-09-26 21:24:36,031 DEBUG: Found 10801 points in 5.37101888657s
2018-09-26 21:24:36,216 DEBUG: Found 10439 points in 5.13060283661s
2018-09-26 21:24:37,448 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090004_0024_RGB.JPG
2018-09-26 21:24:37,615 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090012_0026_RGB.JPG
2018-09-26 21:24:44,375 DEBUG: Found 10776 points in 6.24992704391s
2018-09-26 21:24:44,666 DEBUG: Found 10860 points in 6.34158396721s
2018-09-26 21:24:46,092 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090019_0030_RGB.JPG
2018-09-26 21:24:46,363 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090017_0029_RGB.JPG
2018-09-26 21:24:52,723 DEBUG: Found 10427 points in 5.95635700226s
2018-09-26 21:24:52,988 DEBUG: Found 10524 points in 5.95060896873s
2018-09-26 21:24:54,243 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090026_0033_RGB.JPG
2018-09-26 21:24:54,554 INFO: Extracting ROOT_HAHOG features for image IMG_180810_090013_0027_RGB.JPG
2018-09-26 21:25:00,848 DEBUG: Found 10373 points in 5.95248103142s
2018-09-26 21:25:01,158 DEBUG: Found 10702 points in 5.93945002556s
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm match_features /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/opensfm
2018-09-26 21:25:03,560 INFO: Matching 44 image pairs
2018-09-26 21:25:04,306 INFO: Matching IMG_180810_090012_0026_RGB.JPG - 1 / 10
2018-09-26 21:25:04,894 INFO: Matching IMG_180810_090006_0025_RGB.JPG - 2 / 10
2018-09-26 21:25:10,063 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 6 candidate matches
2018-09-26 21:25:10,658 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090013_0027_RGB.JPG has 1226 candidate matches
2018-09-26 21:25:10,662 DEBUG: Robust matching time : 0.00311207771301s
2018-09-26 21:25:10,662 DEBUG: Full matching 1092 / 1226, time: 5.76821017265s
2018-09-26 21:25:15,509 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 5 candidate matches
2018-09-26 21:25:16,057 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090017_0029_RGB.JPG has 497 candidate matches
2018-09-26 21:25:16,057 DEBUG: Robust matching time : 0.000414133071899s
2018-09-26 21:25:16,058 DEBUG: Full matching 491 / 497, time: 5.39505887032s
2018-09-26 21:25:20,460 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090017_0029_RGB.JPG has 912 candidate matches
2018-09-26 21:25:20,462 DEBUG: Robust matching time : 0.00169086456299s
2018-09-26 21:25:20,463 DEBUG: Full matching 884 / 912, time: 4.9536421299s
2018-09-26 21:25:21,168 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 13 candidate matches
2018-09-26 21:25:25,492 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090013_0027_RGB.JPG has 2568 candidate matches
2018-09-26 21:25:25,494 DEBUG: Robust matching time : 0.00111484527588s
2018-09-26 21:25:25,495 DEBUG: Full matching 2560 / 2568, time: 5.0308599472s
2018-09-26 21:25:26,083 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 4 candidate matches
2018-09-26 21:25:30,528 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090015_0028_RGB.JPG has 1407 candidate matches
2018-09-26 21:25:30,530 DEBUG: Robust matching time : 0.00105404853821s
2018-09-26 21:25:30,530 DEBUG: Full matching 1324 / 1407, time: 5.03530287743s
2018-09-26 21:25:31,125 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090015_0028_RGB.JPG has 726 candidate matches
2018-09-26 21:25:31,127 DEBUG: Robust matching time : 0.00148797035217s
2018-09-26 21:25:31,127 DEBUG: Full matching 653 / 726, time: 5.04339599609s
2018-09-26 21:25:36,314 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 533 candidate matches
2018-09-26 21:25:36,315 DEBUG: Robust matching time : 0.000591039657593s
2018-09-26 21:25:36,324 DEBUG: Full matching 526 / 533, time: 5.79362893105s
2018-09-26 21:25:37,637 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 270 candidate matches
2018-09-26 21:25:37,639 DEBUG: Robust matching time : 0.000932931900024s
2018-09-26 21:25:37,639 DEBUG: Full matching 263 / 270, time: 6.51219201088s
2018-09-26 21:25:43,801 DEBUG: IMG_180810_090012_0026_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 66 candidate matches
2018-09-26 21:25:43,802 DEBUG: Robust matching time : 0.000319004058838s
2018-09-26 21:25:43,802 DEBUG: Full matching 63 / 66, time: 7.47745394707s
2018-09-26 21:25:44,024 INFO: Matching IMG_180810_090013_0027_RGB.JPG - 3 / 10
2018-09-26 21:25:44,719 DEBUG: IMG_180810_090006_0025_RGB.JPG - IMG_180810_090012_0026_RGB.JPG has 2076 candidate matches
2018-09-26 21:25:44,722 DEBUG: Robust matching time : 0.00171184539795s
2018-09-26 21:25:44,722 DEBUG: Full matching 1970 / 2076, time: 7.0823340416s
2018-09-26 21:25:44,896 INFO: Matching IMG_180810_090017_0029_RGB.JPG - 4 / 10
2018-09-26 21:25:58,957 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 1137 candidate matches
2018-09-26 21:25:58,959 DEBUG: Robust matching time : 0.00226998329163s
2018-09-26 21:25:58,973 DEBUG: Full matching 1068 / 1137, time: 14.9482650757s
2018-09-26 21:25:59,995 DEBUG: IMG_180810_090017_0029_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 979 candidate matches
2018-09-26 21:26:00,007 DEBUG: Robust matching time : 0.0104758739471s
2018-09-26 21:26:00,007 DEBUG: Full matching 926 / 979, time: 15.1102559566s
2018-09-26 21:26:08,223 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 398 candidate matches
2018-09-26 21:26:08,225 DEBUG: Robust matching time : 0.000686883926392s
2018-09-26 21:26:08,225 DEBUG: Full matching 395 / 398, time: 9.25210404396s
2018-09-26 21:26:08,850 DEBUG: IMG_180810_090017_0029_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 2952 candidate matches
2018-09-26 21:26:08,853 DEBUG: Robust matching time : 0.0019211769104s
2018-09-26 21:26:08,853 DEBUG: Full matching 2802 / 2952, time: 8.84388399124s
2018-09-26 21:26:13,696 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 44 candidate matches
2018-09-26 21:26:13,697 DEBUG: Robust matching time : 0.000503063201904s
2018-09-26 21:26:13,697 DEBUG: Full matching 39 / 44, time: 5.47170519829s
2018-09-26 21:26:14,244 DEBUG: IMG_180810_090017_0029_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 230 candidate matches
2018-09-26 21:26:14,246 DEBUG: Robust matching time : 0.000688076019287s
2018-09-26 21:26:14,246 DEBUG: Full matching 219 / 230, time: 5.39311099052s
2018-09-26 21:26:19,516 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 36 candidate matches
2018-09-26 21:26:19,517 DEBUG: Robust matching time : 0.000587940216064s
2018-09-26 21:26:19,518 DEBUG: Full matching 32 / 36, time: 5.82073497772s
2018-09-26 21:26:20,109 DEBUG: IMG_180810_090017_0029_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 279 candidate matches
2018-09-26 21:26:20,110 DEBUG: Robust matching time : 0.00045919418335s
2018-09-26 21:26:20,110 DEBUG: Full matching 267 / 279, time: 5.86357617378s
2018-09-26 21:26:20,249 INFO: Matching IMG_180810_090026_0033_RGB.JPG - 5 / 10
2018-09-26 21:26:20,253 INFO: Matching IMG_180810_090019_0030_RGB.JPG - 6 / 10
2018-09-26 21:26:25,436 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090017_0029_RGB.JPG has 2083 candidate matches
2018-09-26 21:26:25,439 DEBUG: Robust matching time : 0.00252890586853s
2018-09-26 21:26:25,455 DEBUG: Full matching 1930 / 2083, time: 5.93689703941s
2018-09-26 21:26:26,313 DEBUG: IMG_180810_090019_0030_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 2055 candidate matches
2018-09-26 21:26:26,314 DEBUG: Robust matching time : 0.000802993774414s
2018-09-26 21:26:26,315 DEBUG: Full matching 2036 / 2055, time: 6.0609869957s
2018-09-26 21:26:31,633 DEBUG: IMG_180810_090013_0027_RGB.JPG - IMG_180810_090015_0028_RGB.JPG has 3706 candidate matches
2018-09-26 21:26:31,636 DEBUG: Robust matching time : 0.00316882133484s
2018-09-26 21:26:31,637 DEBUG: Full matching 3561 / 3706, time: 6.1815931797s
2018-09-26 21:26:31,861 INFO: Matching IMG_180810_090015_0028_RGB.JPG - 7 / 10
2018-09-26 21:26:32,465 DEBUG: IMG_180810_090019_0030_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 382 candidate matches
2018-09-26 21:26:32,466 DEBUG: Robust matching time : 0.000653028488159s
2018-09-26 21:26:32,467 DEBUG: Full matching 340 / 382, time: 6.15180802345s
2018-09-26 21:26:37,917 DEBUG: IMG_180810_090015_0028_RGB.JPG - IMG_180810_090017_0029_RGB.JPG has 3509 candidate matches
2018-09-26 21:26:37,919 DEBUG: Robust matching time : 0.00148892402649s
2018-09-26 21:26:37,919 DEBUG: Full matching 3501 / 3509, time: 6.05773615837s
2018-09-26 21:26:38,368 DEBUG: IMG_180810_090019_0030_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 532 candidate matches
2018-09-26 21:26:38,370 DEBUG: Robust matching time : 0.00145506858826s
2018-09-26 21:26:38,370 DEBUG: Full matching 478 / 532, time: 5.90337014198s
2018-09-26 21:26:38,462 INFO: Matching IMG_180810_090020_0031_RGB.JPG - 8 / 10
2018-09-26 21:26:43,607 DEBUG: IMG_180810_090015_0028_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 1685 candidate matches
2018-09-26 21:26:43,608 DEBUG: Robust matching time : 0.000986814498901s
2018-09-26 21:26:43,609 DEBUG: Full matching 1637 / 1685, time: 5.68965506554s
2018-09-26 21:26:44,319 DEBUG: IMG_180810_090020_0031_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 2118 candidate matches
2018-09-26 21:26:44,322 DEBUG: Robust matching time : 0.00230407714844s
2018-09-26 21:26:44,323 DEBUG: Full matching 1972 / 2118, time: 5.86021614075s
2018-09-26 21:26:51,252 DEBUG: IMG_180810_090015_0028_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 168 candidate matches
2018-09-26 21:26:51,253 DEBUG: Robust matching time : 0.000494956970215s
2018-09-26 21:26:51,253 DEBUG: Full matching 163 / 168, time: 7.64409399033s
2018-09-26 21:26:51,884 DEBUG: IMG_180810_090020_0031_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 1049 candidate matches
2018-09-26 21:26:51,885 DEBUG: Robust matching time : 0.000769853591919s
2018-09-26 21:26:51,885 DEBUG: Full matching 1038 / 1049, time: 7.56197714806s
2018-09-26 21:26:51,969 INFO: Matching IMG_180810_090023_0032_RGB.JPG - 9 / 10
2018-09-26 21:26:57,203 DEBUG: IMG_180810_090015_0028_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 185 candidate matches
2018-09-26 21:26:57,204 DEBUG: Robust matching time : 0.000647068023682s
2018-09-26 21:26:57,204 DEBUG: Full matching 175 / 185, time: 5.95083999634s
2018-09-26 21:26:57,621 DEBUG: IMG_180810_090023_0032_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 1707 candidate matches
2018-09-26 21:26:57,622 DEBUG: Robust matching time : 0.000743865966797s
2018-09-26 21:26:57,623 DEBUG: Full matching 1678 / 1707, time: 5.65299510956s
2018-09-26 21:26:57,671 INFO: Matching IMG_180810_090004_0024_RGB.JPG - 10 / 10
2018-09-26 21:27:02,879 DEBUG: IMG_180810_090015_0028_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 668 candidate matches
2018-09-26 21:27:02,880 DEBUG: Robust matching time : 0.00042986869812s
2018-09-26 21:27:02,880 DEBUG: Full matching 658 / 668, time: 5.67578601837s
2018-09-26 21:27:03,248 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090019_0030_RGB.JPG has 422 candidate matches
2018-09-26 21:27:03,250 DEBUG: Robust matching time : 0.00112509727478s
2018-09-26 21:27:03,251 DEBUG: Full matching 416 / 422, time: 5.57940506935s
2018-09-26 21:27:07,711 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090020_0031_RGB.JPG has 91 candidate matches
2018-09-26 21:27:07,712 DEBUG: Robust matching time : 0.000420093536377s
2018-09-26 21:27:07,712 DEBUG: Full matching 86 / 91, time: 4.46001887321s
2018-09-26 21:27:11,867 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090023_0032_RGB.JPG has 6 candidate matches
2018-09-26 21:27:16,236 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090026_0033_RGB.JPG has 3 candidate matches
2018-09-26 21:27:21,647 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090012_0026_RGB.JPG has 1691 candidate matches
2018-09-26 21:27:21,649 DEBUG: Robust matching time : 0.00138592720032s
2018-09-26 21:27:21,649 DEBUG: Full matching 1643 / 1691, time: 5.41260004044s
2018-09-26 21:27:25,757 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090013_0027_RGB.JPG has 1300 candidate matches
2018-09-26 21:27:25,759 DEBUG: Robust matching time : 0.00165200233459s
2018-09-26 21:27:25,760 DEBUG: Full matching 1242 / 1300, time: 4.11097383499s
2018-09-26 21:27:30,769 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090017_0029_RGB.JPG has 646 candidate matches
2018-09-26 21:27:30,770 DEBUG: Robust matching time : 0.000684022903442s
2018-09-26 21:27:30,770 DEBUG: Full matching 633 / 646, time: 5.009567976s
2018-09-26 21:27:35,309 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090015_0028_RGB.JPG has 906 candidate matches
2018-09-26 21:27:35,310 DEBUG: Robust matching time : 0.000922918319702s
2018-09-26 21:27:35,310 DEBUG: Full matching 885 / 906, time: 4.53854608536s
2018-09-26 21:27:39,464 DEBUG: IMG_180810_090004_0024_RGB.JPG - IMG_180810_090006_0025_RGB.JPG has 2555 candidate matches
2018-09-26 21:27:39,466 DEBUG: Robust matching time : 0.00123691558838s
2018-09-26 21:27:39,466 DEBUG: Full matching 2547 / 2555, time: 4.15584111214s
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm create_tracks /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/opensfm
2018-09-26 21:27:40,423 INFO: reading features
2018-09-26 21:27:41,051 DEBUG: Merging features onto tracks
2018-09-26 21:27:41,622 DEBUG: Good tracks: 12296
[DEBUG] running PYTHONPATH=/code/SuperBuild/install/lib/python2.7/dist-packages /code/SuperBuild/src/opensfm/bin/opensfm reconstruct /var/www/data/45da4986-59d6-4e61-b971-98c5036495b9/opensfm
2018-09-26 21:27:43,396 INFO: Starting incremental reconstruction
File “/code/SuperBuild/src/opensfm/bin/opensfm”, line 34, in
command.run(args)
File “/code/SuperBuild/src/opensfm/opensfm/commands/reconstruct.py”, line 21, in run
report = reconstruction.incremental_reconstruction(data)
File “/code/SuperBuild/src/opensfm/opensfm/reconstruction.py”, line 1161, in incremental_reconstruction
pairs = compute_image_pairs(common_tracks, data)
File “/code/SuperBuild/src/opensfm/opensfm/reconstruction.py”, line 416, in compute_image_pairs
result = parallel_map(_compute_pair_reconstructability, args, processes)
File “/code/SuperBuild/src/opensfm/opensfm/context.py”, line 38, in parallel_map
return list(e.map(func, args))
File “/usr/local/lib/python2.7/dist-packages/loky/process_executor.py”, line 788, in _chain_from_iterable_of_lists
for element in iterable:
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 589, in result_iterator
yield future.result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 433, in result
return self.__get_result()
File “/usr/local/lib/python2.7/dist-packages/loky/_base.py”, line 381, in __get_result
raise self._exception
loky.process_executor.TerminatedWorkerError:
A worker process managed by the executor was unexpectedly terminated. This could be caused by a segmentation fault while calling the function or by an excessive memory usage causing the Operating System to kill the worker.
Exception in thread QueueFeederThread (most likely raised during interpreter shutdown):
File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
File “/usr/lib/python2.7/threading.py”, line 754, in run
File “/usr/local/lib/python2.7/dist-packages/loky/backend/queues.py”, line 151, in _feed
File “/usr/local/lib/python2.7/dist-packages/loky/backend/reduction.py”, line 145, in dumps
File “/usr/lib/python2.7/pickle.py”, line 224, in dump
File “/usr/lib/python2.7/pickle.py”, line 331, in save
File “/usr/lib/python2.7/pickle.py”, line 425, in save_reduce
File “/usr/lib/python2.7/pickle.py”, line 286, in save
File “/usr/lib/python2.7/pickle.py”, line 568, in save_tuple
File “/usr/lib/python2.7/pickle.py”, line 606, in save_list
File “/usr/lib/python2.7/pickle.py”, line 621, in _batch_appends
File “/usr/lib/python2.7/pickle.py”, line 655, in save_dict
File “/usr/lib/python2.7/pickle.py”, line 670, in _batch_setitems
<type ‘exceptions.TypeError’>: ‘NoneType’ does not have the buffer interface
plasm.execute(niter=1)
File “/code/scripts/run_opensfm.py”, line 133, in process
(context.pyopencv_path, context.opensfm_path, tree.opensfm))
File “/code/opendm/system.py”, line 34, in run
Exception: Child returned 1
We fixed this a few hours ago. Run ./webodm.sh update and reprocess the dataset. It should work.
Thanks a lot! It worked for the 10 pics and now I’m processing the whole dataset…let you know if the problem still persists
