Process exited with code 1 . Unable to process any image
I am unable to process any set of images . It always giving me error “Increase the min-num-features option, especially if your images have lots of vegetation”
I tried to increase min-num-features to any higher integer but there is no luck at all . I have tried to use different settings mentioned in community post but it does not solve that issue .
here is the set of images i am trying to process https://github.com/merkato/odm_boruszyn_kap/
here is the output https://www.dropbox.com/s/l0q2bb4p4kwwc24/task_output.txt?dl=0
Note : I am running docker with windows
Please let me know how to fix that issue
If your computer has an old or 32bit CPU, you need to compile OpenDroneMap from sources. You cannot use docker. Docker images work with CPUs with 64-bit extensions, MMX, SSE, SSE2, SSE3 and SSSE3 instruction set support or higher.
