PotreeConverter is not installed, will skip generation of Potree point cloud
Hello ,
Thank you for your hard work on WebOdm.
Webodm is installed via install script at fresh install of Ubuntu 16.04.5 (kvm virtual environment / qemu-system 4core AMD cpu(all instructions exposed) 8GB RAM )
The interface is running fine.
I have proccesed sample data (141 pictures downloaded from: here
Point cloud is missing and I get the error :PotreeConverter is not installed, will skip generation of Potree point cloud
task_output.txt
Any suggestion?
Thank you ,again.
PS: I had to compile and install it by hand . Now works as expected .
PotreeConverter instructions
Thank You again for this amazing software.
