Output and Results of ODM
Could someone help me understand the workflow of ODM processing?
I understood few things from this link : https://github.com/OpenDroneMap/OpenDroneMap/wiki/Output-and-Results
Also tried processing few images successfully.However, I couldnt figure out what the other files in different output folders mean.
For eg: Opensfm has many files…
Also, any leads on where can i find the camera parameters - (both external and internal) being used by the program? I require something called as camera or projection matrix from those values.
I am new to computer vision discipline and trying to learn things.
Thank you.
See this thread: Where can I find background information on the concepts of ODM?
Intrinsics parameters are stored in opensfm/camera_models.json, extrinsics are in opensfm/reconstruction.json and opensfm/geocoords_transformation.txt.
Welcome to the field!
