OSError: [Errno 16] Device or resource busy: '/code/smvs'
Hi all,
I was trying to run the ODM using docker image. Following is the command I entered :
docker run -it --rm -v “/home/ODM_input_datsets:/code/images” -v “$(pwd)/odm_orthophoto:/code/odm_orthophoto” -v “$(pwd)/opensfm:/code/opensfm” -v “$(pwd)/odm_georeferencing:/code/odm_georeferencing” -v “$(pwd)/odm_meshing:/code/odm_meshing” -v “$(pwd)/odm_texturing:/code/odm_texturing” -v “$(pwd)/gcp_list.txt:/code/gcp_list.txt” -v “$(pwd)/smvs:/code/smvs” opendronemap/opendronemap --depthmap-resolution 1000 --opensfm-depthmap-min-consistent-views 2 --opensfm-depthmap-method “BRUTE_FORCE” --matcher-distance 400 --ignore-gsd --mesh-point-weight 0 --texturing-nadir-weight 32 --use-3dmesh --crop 0 --orthophoto-resolution 2.57 --mesh-size 1000000 --texturing-skip-visibility-test --texturing-data-term “area” --time --min-num-features 12000 --mesh-octree-depth 12 --resize-to -1
I deleted previous docker images and built a new one after the latest release…
However, it returns an error as below : (copied the last few lines)
[INFO] Running ODM OpenSfM Cell - Finished
[INFO] Running SMVS Cell
plasm.execute(niter=1)
File “/code/scripts/smvs.py”, line 63, in process
shutil.rmtree(tree.smvs)
File “/usr/lib/python2.7/shutil.py”, line 256, in rmtree
onerror(os.rmdir, path, sys.exc_info())
File “/usr/lib/python2.7/shutil.py”, line 254, in rmtree
os.rmdir(path)
OSError: [Errno 16] Device or resource busy: ‘/code/smvs’
The same dataset ran successfully on native installation using run.sh script…but problem comes when using docker.
Could someone please help.
Thank you.
Using GCP's in Open drone map
Also experiencing this, using opendronemap/opendronemap:0.4.0
the approach defined here worked: https://github.com/OpenDroneMap/OpenDroneMap/issues/902
