Node-odm-1 remove
Everetime when I started webodm again even if I remove the default node-odm-1 then it will be added again. It really annoying because the adding the processing node to the same computer where the web-service is - strange behavour. This computer is weak to process something so I need to temporary remove it.
this thing is real annoying.
For example you restarted the server. Then the default node is adding again,
The next job will use the default node.
The RAM and cpu consumption will be extreme for web server.
Then it hangs or kernel except and breaks.
