Nearly 24 hours processsing - Not sure if worth stopping?
I have a job going which has been stuck on this bit -
“READING: odm_georeferencing/odm_georeferenced_model.las”
Activity monitor is showing that docker is using some CPU but it doesn’t look like it’s stressing it much.
Should i let it carry on or do you think it’s stuck? I have pushed up the numbers in the settings to try get some good results but i didn’t expect it to take this long…
I just want a map that doesn’t have a creased paper effect on flat surfaces :frowning: lol
38
It’s probably is stuck. Have you allocated enough RAM to your docker environment?
14GB assigned to docker.
Anyway, i started it again and it finished in 2.5 hours haha. Ah well.
Thanks!
#4
If it happens again, please let us know. I think I’ve seen this problem before, but I haven’t been able to identify the cause. :wine_glass:
Are you running the latest version of WebODM (have you updated within the last two weeks)?
#5
No problem, and yes it was updated before starting that job.
I’m going to try up the settings again now for another run…Do you perhaps know how i can fix this effect?
37
#6
Is that your orthophoto? If so, can you upload your dataset somewhere (Google Drive, Dropbox) and tell us which parameters you used?
#7
Sorry i should have said - this is my 3D textured model.
The orpho is fine :slight_smile:
#8
I think you just need to turn off the lights in the program you are using to display the textured model. There’s nothing wrong with the output.
#9
Seems you’re right! Loading it up in Meshlab shows better results, though i can’t see a way of changing any lighting options using WebODM viewer. Never though.
Thanks again.
