Native Install on Ubuntu
I am trying to install WebODM natively under Ubuntu 16.04 using the community provided script:
I have two questions:
a) At the end of the script it configures docker… so is it not really native? I plan to use this on a virtual machine and don’t want performance to be much degraded.
b) When the script finishes, is there any other step I must complete in order to be able to connect and start working? What URL should I use to connect to the newly configured machine?
Thanks in advance,
Jose
The community script is installing WebODM natively, but I think it assumes that node-OpenDroneMap and OpenDroneMap are installed using docker. You can follow the instructions on https://github.com/OpenDroneMap/OpenDroneMap and https://github.com/OpenDroneMap/node-OpenDroneMap to install those natively as well.
If you need a script that installs everything natively and you want to save some time, you could also consider supporting the project by purchasing https://www.opendronemap.org/webodm/server-installer/.
I’m pretty much a newbie and no ubuntu power user either… I was not aware of the script for installing but I first tried installing on a virtual server on digital ocean. Hit a snag when it could not find docker… and I didnt know how to set the path to docker. I created a new server with docker already installed… one of the one click installs. I then ran the webodm install… had to add pip manually… once installed I could access the it via the machines IP:8000
