Memory experience
I’m testing WebODM on different operating systems and on different hardware.
My drone: Phanthom 4 Pro.
1st configuration:
My local test computer with Windows 10 Prof, Intel i7 and 8GB RAM and the WebODM Installer runs well with WebODM, but with the 6 GB memory allocated for Docker I can only calculate small projects.
If, for example, I want to calculate a flight with 80 images, the memory seems to be insufficient.
1st question: How much RAM do I need with a Windows environment to calculate up to 150 images?
2nd configuration:
Linux server with Ubuntu 16.04 as VPS with 16 GB Ram and 6 cores. WebODM installed by hand, everything works fine.
Here, too, the RAM seems to be too tight. WebODM aborts with 88 images.
2nd question: is there a set memory limit for Docker under a Linux installation?
docker info returns the following result:
Containers: 5
Running: 5
Paused: 0
Stopped: 0
Images: 4
Server Version: 18.06.1-ce
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file logentries splunk syslog
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 468a545b9edcd5932818eb9de8e72413e616e86e
runc version: 69663f0bd4b60df09991c08812a60108003fa340
init version: fec3683
Security Options:
apparmor
seccomp
Profile: default
Kernel Version: 4.4.0-135-generic
Operating System: Ubuntu 16.04.5 LTS
OSType: linux
Architecture: x86_64
CPUs: 4
Total Memory: 11.73GiB
Docker Root Dir: /var/lib/docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
WARNING: No swap limit support
Thanks Sven
Hi
I dont know the answers for all your questions. But hopefully I can help you along with some of them.
I have been testing with a dataset of around 100 images with a size of 500MB in total and 20GB of ram was not always enough depending on the settings.
I have better results with running ODM standalone as a docker image with my dataset to avoid memory errors. Than running it through WebODM.
If you want to see the memory limit on docker you can run “docker containers stats”
Thank you for your answer. Meanwhile I have come further and am now testing under the following environment, which is promising:
CPUs: 6
Total Memory for docker: 23.55 GB
204 files with 1,6 GB are calculated in 3:25 hours (Processingnode Auto, options default , no resize)
I will now systematically carry out further tests and report.
Greetings Sven
#4
Hi
These are some of my memory experiences with ODM and a small dataset on a 16 way server with 50GB RAM:
Dataset Images Pix Size Time CPU count MaxMem(GB) settings
house 75 12 415M 18:00.67 30 8 default
house 75 12 415M 11:26.37 30 7 –fast-orthophoto
house 75 12 415M 1:01:00 30 19,5 –min-num-features 15000 --matcher-neighbors 12 --texturing-data-term area --mesh-octree-depth 12 --skip-3dmodel
house 75 12 415M 1:01:00 30 18 –min-num-features 20000 --matcher-neighbors 12 --texturing-data-term area --mesh-octree-depth 12 --skip-3dmodel
house 30 12 194M 4:19.00 30 5 –fastorthop
house 30 12 194M 3:58 16 3.5 –fastorthop
house 30 12 194M 7:06.00 16 3.7 default
house 75 12 415M 9:21 16 6.2 –fast-orthophoto
house 75 12 415M 16:50.00 16 6.2 default
house 75 12 415M 48:28.00 16 19 –min-num-features 15000 --matcher-neighbors 12 --texturing-data-term area --mesh-octree-depth 12 --skip-3dmodel
#5
This is incredibly useful. Thanks for sharing this.
