Made some gcp's but can't import them correctly
Last sutherday i made some GPS control points with my trimble, the format that i get from this device are:
2,52°24’03.82773"N,6°16’36.30721"E,47.852,asf-n
4,52°24’05.17315"N,6°16’39.21870"E,47.922,asf-n
3,52°24’07.01367"N,6°16’35.09524"E,47.457,asf-n
1,52°24’05.18540"N,6°16’33.88689"E,47.530,asf-n
5,52°24’05.02707"N,6°16’36.55102"E,47.853,piket
Or like this:
1,215492.373,490771.771,4.555,asf-n
2,215538.642,490730.374,4.876,asf-n
3,215514.522,490828.555,4.483,asf-n
4,215593.168,490772.631,4.947,asf-n
5,215542.795,490767.497,4.877,piket
What is the best way to make the GCP_list.txt file. I have done several formats but each time it will not load or it loads but i get no points on the map. I use a mavic pro to fly over the controle points that i marked on the ground.
Here are the photo’s that i shot:
https://jhaarman-my.sharepoint.com/:f:/g/personal/joost_joosthaarman_nl/ErmfT8QwUBdMmKDvLiuqavAB0d9IdzG2Wm9bACP9T0xbRw?e=OIlvAT
Hi @aapie – your best bet is to convert the first set of coordinates to decimal degrees instead of degrees, minutes, decimal seconds. Here’s one website for doing this:
Then, as your header / first line, add the proj4 string:
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
Let us know how it goes!
First of all thank you for your reply. This is what i have now, but it stil not apear on the map. De file loads but no gcp’s are seen on the map.
gcp01 52.401440 6.276079
gcp02 52.401063 6.276752
gcp03 52.401948 6.276415
gcp04 52.401437 6.277561
gcp05 52.401396 6.27682
I have tried several possibilities. I make the file in notepad is this ok?
If i put one of the coordinates in google maps is shows the right spot.
#4
Ok, i am a step forwards.
gcp01 6.276079 52.401440
gcp02 6.276752 52.401063
gcp03 6.276415 52.401948
gcp04 6.277561 52.401437
gcp05 6.276820 52.401396
Is shows point 3,4 and 5… But 1 and 2 not…
#5
Try adding your Z value too (in meters).
#6
Super weird, i added the Z value, it did not show. Then i deleted the Z value. Tried again and all the 5 points shows up on the map. Its the same setting as before. Can it be that there are some hidden tabs or spaces?
#7
But it works for now… is running the images. Next time i try to add height. Thx for the support!
6.28 52.40 0 658.09 595.57 DJI_0580.JPG gcp01
6.28 52.40 0 686.40 1293.01 DJI_0581.JPG gcp01
6.28 52.40 0 702.50 1978.50 DJI_0582.JPG gcp01
6.28 52.40 0 733.50 2672.50 DJI_0583.JPG gcp01
6.28 52.40 0 2867.75 1032.00 DJI_0623.JPG gcp01
6.28 52.40 0 2908.00 1715.25 DJI_0624.JPG gcp01
6.28 52.40 0 2931.75 2412.25 DJI_0625.JPG gcp01
6.28 52.40 0 2355.50 207.75 DJI_0597.JPG gcp02
6.28 52.40 0 2363.75 885.25 DJI_0598.JPG gcp02
6.28 52.40 0 2357.25 1551.25 DJI_0599.JPG gcp02
6.28 52.40 0 2363.00 2238.00 DJI_0600.JPG gcp02
6.28 52.40 0 2673.50 324.00 DJI_0612.JPG gcp02
6.28 52.40 0 2680.50 1004.25 DJI_0613.JPG gcp02
6.28 52.40 0 2702.25 1723.00 DJI_0614.JPG gcp02
6.28 52.40 0 2712.25 2408.75 DJI_0615.JPG gcp02
6.28 52.40 0 2346.25 532.50 DJI_0457.JPG gcp03
6.28 52.40 0 2346.00 1279.00 DJI_0458.JPG gcp03
6.28 52.40 0 2320.00 1953.25 DJI_0459.JPG gcp03
6.28 52.40 0 2301.50 2605.50 DJI_0460.JPG gcp03
6.28 52.40 0 2727.50 368.25 DJI_0493.JPG gcp03
6.28 52.40 0 2735.50 1039.25 DJI_0494.JPG gcp03
6.28 52.40 0 2732.25 1717.25 DJI_0495.JPG gcp03
6.28 52.40 0 2748.00 2389.25 DJI_0496.JPG gcp03
6.28 52.40 0 1157.00 877.50 DJI_0440.JPG gcp04
6.28 52.40 0 1467.75 1263.00 DJI_0441.JPG gcp04
6.28 52.40 0 1552.75 1884.00 DJI_0442.JPG gcp04
6.28 52.40 0 1574.50 2517.25 DJI_0443.JPG gcp04
6.28 52.40 0 1326.25 2901.75 DJI_0476.JPG gcp04
6.28 52.40 0 3724.50 614.00 DJI_0478.JPG gcp04
6.28 52.40 0 3640.75 1397.25 DJI_0479.JPG gcp04
6.28 52.40 0 3615.50 2067.50 DJI_0480.JPG gcp04
6.28 52.40 0 3200.75 809.25 DJI_0507.JPG gcp05
6.28 52.40 0 3198.75 1453.25 DJI_0508.JPG gcp05
6.28 52.40 0 3196.25 2114.75 DJI_0509.JPG gcp05
6.28 52.40 0 3197.50 2758.25 DJI_0510.JPG gcp05
6.28 52.40 0 1785.00 624.25 DJI_0527.JPG gcp05
6.28 52.40 0 1806.25 1288.00 DJI_0528.JPG gcp05
6.28 52.40 0 1807.00 1956.50 DJI_0529.JPG gcp05
6.28 52.40 0 1833.35 2641.84 DJI_0530.JPG gcp05
#8
The proces is done, but after tis i get a error message. Does anyone has any suggestions?
Created on: 9-5-2018 00:16:53
Status: Completed
Options: dsm: true, mesh-octree-depth: 6, mesh-solver-divide: 6, dem-resolution: 0.04, orthophoto-resolution: 40
An orthophoto could not be generated. To generate one, make sure GPS information is embedded in the EXIF tags of your images, or use a Ground Control Points (GCP) file.
