Linux Debian Jessie 8.0 64bit CMAKE Issue
From @TheVidar on Sun Feb 12 2017 19:09:36 GMT+0000 (UTC)
After running ./configure.sh
I’m presented with a message
Installing OpenDroneMap Dependencies
Compiling SuperBuild
CMake Error at CMakeLists.txt:1 (cmake_minimum_required):
CMake 3.1 or higher is required. You are running version 3.0.2
– Configuring incomplete, errors occurred!
Compiling build
CMake Warning at modules/odm_georef/CMakeLists.txt:16 (find_package):
Could not find a package configuration file provided by “PCL” (requested
version 1.7) with any of the following names:
PCLConfig.cmake
pcl-config.cmake
Add the installation prefix of “PCL” to CMAKE_PREFIX_PATH or set “PCL_DIR”
to a directory containing one of the above files. If “PCL” provides a
separate development package or SDK, be sure it has been installed.
CMake Error at modules/odm_georef/CMakeLists.txt:19 (find_package):
Could not find a package configuration file provided by “OpenCV” with any
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of “OpenCV” to CMAKE_PREFIX_PATH or set
“OpenCV_DIR” to a directory containing one of the above files. If “OpenCV”
provides a separate development package or SDK, be sure it has been
installed.
See also “/home/drone/OpenDroneMap/CMakeFiles/CMakeOutput.log”.
Configuration Finished
Also during the process I’m seeing this
W: Failed to fetch http://ppa.launchpad.net/george-edison55/cmake-3.x/ubuntu/dists/jessie/main/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installing Required Requisites
When running:
File “/home/drone/OpenDroneMap/run.py”, line 9, in
import ecto
ImportError: No module named ecto
Please advise.
Copied from original issue: https://github.com/OpenDroneMap/OpenDroneMap/issues/482
From @dakotabenjamin on Tue Feb 14 2017 16:21:58 GMT+0000 (UTC)
That line in configure.sh should probably have a check for operating system. In your case you need to manually ensure that the CMake version is at least 3.1, then comment that line out and run again.
The last error you got (no module) is because your environmental parameters are not set correctly
From @yjmenezes on Wed Feb 15 2017 23:11:00 GMT+0000 (UTC)
@TheArceth
for PPA, try this:
Debian Wheezy:
sudo apt-get install python-software-properties
about octo, I have same error:
import ecto
could it be case sensitive MD5 check inside External-Catkin.cmake ?
[ 40%] Performing download step (download, verify and extract) for ‘catkin’
– downloading…
src=‘https://github.com/ros/catkin/archive/0.6.16.zip
dst=’/home/jmenezes/OpenDroneMap/SuperBuild/download/0.6.16.zip’
timeout=‘none’
– [download 69% complete]
[ 85%] Building CXX object libs/tex/CMakeFiles/tex.dir/texture_view.cpp.o
– [download 70% complete]
– verifying file…
file=’/home/jmenezes/OpenDroneMap/SuperBuild/download/0.6.16.zip’
– MD5 hash of
does not match expected value
expected: ‘F5D45AE68709CE6E3346FB8C019416F8’
actual: ‘f5d45ae68709ce6e3346fb8c019416f8’
– Hash mismatch, removing…
I change from Upper to lower case and it fix Hash mismatch.
URL_MD5 F5D45AE68709CE6E3346FB8C019416F8
URL_MD5 f5d45ae68709ce6e3346fb8c019416f8
but i have same error again:
import ecto
#4
From @yjmenezes on Thu Feb 16 2017 12:07:44 GMT+0000 (UTC)
@TheArceth
try fix three cmakes URL_MD5 to lowercase.
External-Ecto.cmake
External-OpenSfM.cmake
[]s
julio
#5
From @TheVidar on Fri Feb 17 2017 12:59:32 GMT+0000 (UTC)
Thank you, I will attempt these on a debian machine but for now reverted to Ubuntu 16.04 LTS.
Before this I did manage to get cmake3.1 installed which was minimum requirement, however could not get it installed with SSL support thus meaning it could not pull items from https git repos. Removing the HTTPS would work however long winded.
#6
From @dakotabenjamin on Tue Feb 21 2017 14:11:16 GMT+0000 (UTC)
The ecto error is due to the environment variable LD_LIBRARY_PATH not being set correctly. Check the instructions in the README to set those properly.
#7
From @hblanken on Mon Apr 24 2017 04:45:42 GMT+0000 (UTC)
For anyone who is interested to run ODM on Debian Jessie, here are all the custom steps I did to get ODM running successfully. Thanks @yjmenezes @dakotabenjamin :
#install custom cmake>3.1
sudo apt-get install build-essential
wget http://www.cmake.org/files/v3.7/cmake-3.7.1.tar.gz
tar xzf cmake-3.7.1.tar.gz
cd cmake-3.7.1
./configure
make
#If make finishes without errors:
sudo make install
export PATH=/usr/local/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
cmake --version # This should give v3.7.1
#clone ODM
#change all uppercase hash keys to lowercase for each .cmake file in the directory: ./SuperBuild/cmake/
#Adjust project path in: nano settings.yaml
project_path: ‘/your/path/OpenDroneMap/’
#Configure nano ~/.bashrc
export PYTHONPATH=$PYTHONPATH:/your/path/OpenDroneMap/SuperBuild/install/lib/python2.7/dist-packages
export PYTHONPATH=$PYTHONPATH:/your/path/OpenDroneMap/SuperBuild/src/opensfm
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/your/path/OpenDroneMap/SuperBuild/install/lib
#install ODM
bash configure.sh install
#copy image files over into project path
#run odm
python run.py -i /path/to/images project-name
Yeah! Everything should work on Debian Jessie :slight_smile:
