Just a thank you!
I would just like to thank @pierotofy and others for assistance and swift responses when issues crop up with us dummies.
Also, I am very impressed with WebODM and its outputs!
Keep it going.
STOP! Having issues processing images with WebODM?
  1. Search the forum to see if this problem happened to other users.
  2. Check https://github.com/OpenDroneMap/WebODM/issues for similar problems.
  3. Check https://github.com/OpenDroneMap/OpenDroneMap/issues for similar problems.
Found nothing? Continue below, making sure to:
  1. Include a link to your images! You can use https://www.dropbox.com or https://drive.google.com. No images = difficult to help.
  2. Copy/paste the entire task output (not just parts of it) for everyone to read.
  3. Did you fine tune any parameters? Which ones?
  4. What browser are you using? What operating system? How did you install WebODM? Be precise.
  5. DO NOT address your message to the moderator, a core developer, or any other specific user. The forum is a place where everyone can help answer questions, not just one particular user! Be inclusive of everyone.
  6. DO NOT reply to a topic that is several months old (unless you are posting the answer to a solution). Open a new topic instead.
  7. DO be kind and polite to others.
Remove this notice before posting. Thank you so much!
Very much appreciated. By the nature of the job, we mostly see the problems, so a little praise goes a long way.
I too appreciate the work you have done and continue to do… I have enjoyed getting back under the open source hood… it is quite a piece of work and has been quite the learning curve for this old man. I have made some good connections at the local python user group. Looking into micro python on ESP32.
