GeoTIFF Input
Hi guys,
Love the program. I am having great success with processing JPEGs to make an orthophoto. However, I want to use GeoTIFF inputs instead of JPEGs, if possible. I am flying a MAPIR Survey3 camera. This guy captures both JPEGs and RAW inputs, which can be converted into GeoTIFFs. When I upload the GeoTIFFs into the WebODM interface and start processing the message below notifies me of failure within seconds. I believe it is tagged with the GPS coordinates in the correct way. Looks to me like WebODM does not support GeoTIFF inputs. Is that correct?
Thanks,
-CB
WebODM Output:
[DEBUG] Loading dataset from: /var/www/data/344dfce9-e3d2-4ed2-9910-5ec4b867038d/images
[DEBUG] /var/www/data/344dfce9-e3d2-4ed2-9910-5ec4b867038d/images
[ERROR] Not enough supported images in /var/www/data/344dfce9-e3d2-4ed2-9910-5ec4b867038d/images
[INFO] OpenDroneMap app finished - Mon Jul 02 19:42:28 2018
Postprocessing: /var/www/data/344dfce9-e3d2-4ed2-9910-5ec4b867038d
No orthophoto found at odm_orthophoto/odm_orthophoto.tif: will skip tiling
Potree point cloud will not be generated (no suitable input files found)
Compressing all.zip
Hi @colin.burt :hand: you are most correct, currently we don’t have have support for GeoTIFF images, but other users have inquired about this feature before, so it’s in our pipeline.
We currently have a few other priorities in the works, so help or funding would certainly speed things up.
