Georeferencing Error
What’s your browser and operating system?
On an Windows 8.1 Pro I’ve Oracle VM Virtualbox v5.2.8. running a Xubuntu 16.04.4 LTS, using Firefox v.59.0.2. The VM has 12Gb of memory and 6 CPUs with 300Gb of virtual disk.
How did you install WebODM?
I’ve installed WebODM from command line on the Xubuntu OS running on a Windows VM. And updated recently (yesterday via update command line).
Using which environment?
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
What’s the error?
I’ve processed a set of 155 images and 1 GCP file with the High Quality preset and the map view went fine (dsm: true, mesh-octree-depth: 6, mesh-solver-divide: 6, dem-resolution: 0.04, orthophoto-resolution: 40, no resize).
highquality_ok
When I did the other presets as the Default ou the DSM+DTM the georeferencing with the same 155 photos and the same GCP file (dsm: true, mesh-octree-depth: 6, mesh-solver-divide: 6, no resize)
default_notok!
Output file for the error processing
Output.txt
GCP text file
GCP text file used on all processing
Addendum
Same error happened to the DSM+DTM preset (pic bellow).
dsm%20dtm_notok
Output text file for DSM+DTM preset
Output_DSM-DTM_file.txt
Important (?)
None of these errors happened when processing with the same presets (Default, High Quality, DSM+DTM) without the GCP text file.
